Question about Hitachi 55PD8800 55 in. Plasma Television
55 inch hitachi plasma
Works ok but has about 10cm line in centre and stops half way down the screen. This comes and goes with picture color. How can I fix?
  • 668 Answers
It is either a bad Plasma Panel or the Driver Board that drives that part of the screen. Some of these you can't get one without the other which means big bucks for a Plasma Panel. If that is the case it would not be worth repairing.
Replacement of the unit would be as costly.
Hope this helps,
Skyassoc
Posted on Jun 18, 2009
    President:
  • Hitachi Master
  • 1,779 Answers
Try re-seating your upper and lower buffer board connectors. These boards run the length of the set on top and bottom. Since your line is from the top going down I would check that one. The connector will be close to where the line is showing up on the screen.
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Having a problem with plasma tv hitachi
It will depend on the age of the set but the lines are either a bad board or a bad display unit .
Dec 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Vertical white lines on screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 10, 2017 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
52 inch Hitachi rear projection HDTV. No picture. Just vertical colored lines.
Apr 15, 2017 | Mitsubishi WD-52525 52" Rear Projection...
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Black line down the center of screen
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Dec 31, 2007 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
My tv is hitachi 55pd plasma
have a tech check your tv the vertical module needs to be replaced.good luck
Apr 18, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hitachi 55PD8800 55 in. Plasma Television Logo
150 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
