Question about Mtd 22" Yard Machine Push Mower
The new pull cord will not rewind back - Mtd 22" Yard Machine Push Mower
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
How to replace pull cord on mtd yard machine cultivator 31cc
-Remove the cord or rope assembly. then rewind the unit and then attach the new rope to. After install the new rope. Try to pulls out to see it will rewind back or not. If not rewind more.
Good luck
Mai
Jun 19, 2014 | Garden
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
Pull start cord won't rewind model no RLT30CET curved shaft electric start
There is a spring there you don't need to buy one use the old one.. If you need one go online give them model number have in two days.... Good luck..
Sep 15, 2012 | Garden
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
How do i replace pull string on craftsman 20/14 chainsaw
Remove the cover containing the cord rewind mechanism, untie the cord's knot in the center of the mechanism and remove the old cord by unwinding it from the pulley. Thread the new cord through the hole it goes through on the outside and wind the recoil mechanism so that it has sufficient spring tension to rewind the new cord. Use something appropriate to immobilize the pulley while you thread the cord through the center and tie the knot. Slowly allow the pulley to retract and wind the new cord onto it. Replace the cover. As an aside, sometimes when the cord breaks and the pulley snaps back quickly, the rewind spring can break.
Jun 24, 2011 | Garden
Lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
May 04, 2010 | Mtd 22" Yard Machine Push Mower
When I pull the starter cord there is no tension. The cord basically falls out of the weed eater. I pulled it apart and it will work for about one pull and not a second. When I took it apart a very small...
Ouch. It sounds like the cord rewind spring has gotten out of position. These things can be holy terrors to get back in the cavity in which they rest.
Check on a new rewind spring assembly. This might be more cost effective than trying to get a service person to put the spring back into place.
Oct 18, 2009 | Husqvarna Forest & Garden 125c 17"...
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
How do I repair a broken pull cord on a yardman push mower?
Easier than you might think. You need a screwdriver along with the sockets to remove the housing over the rewind assembly. Once you have the housing off and access to the assembly, remove the old cord by using it to wind the spring all the way out. Before you take the cord out slip a screwdriver in the slots to keep it from winding back up. If it does, it's not a concern. Just wind the spring back out by turning the rewind until it stops, then turn it back one turn until the holes line up for the cord. Stick the new cord through and tie it off, and let the spring pull the new cord in. If you need any help with it, hit me up.
May 12, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
14 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
