Nikai led how to work usb in nikai ntv3272 led2
I have NIKAI led Tv model :ntv 5000csled syucked on standby
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 27, 2017 | Televison & Video
Vizio E470i-A0 not powering up, the standby led comes on momentary when the pwr button is pressed. The voltage on led1/led2 would spike to 130v when powered then bleed down. Are my led strips are bad?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 14, 2016 | Vizio E-Series E470I-A0 47" LED TV...
PANASONIC DMR BS850 SHOWING ERROR CODE F5 202 CAN IT BE FIXED
hi,
Fault Code At Remote = F5
Indoor Unit PCB
LED1 = Lit
LED2 = Lit
LED3 = Lit
LED4 = Lit
Outdoor Unit PCB
LED1 = Lit
LED2 =
LED3 =
LED4 =
Measuring Of Fault Code = Signal from RC to ID faulty.
Air Conditioning Fault Codes
Feb 28, 2014 | Heating & Cooling
I forget my security code of nikai tv
i want service code for nikai tv
May 16, 2010 | Televison & Video
No video and red led lights up
Try a isolation test.
Remove MB from case and put on a piece of cardboard, then hook everything back up to it and see if it powers up.
You have 2 LED's
LED1 Onboard 3VSB LED for SDRAM
LED2 Onboard Power LED
Look @ page 19 & 20 of this manual..
I hope this helps, if so please rate our solution.
Mar 14, 2010 | EliteGroup P6VAP-A+ Motherboard
Front panel conections SE7221BA1-E
Use this link to find the manual:
http://www.intel.com/support/motherboards/desktop/d850mv/sb/cs-009917.htm
Mar 17, 2009 | Intel D850MV Motherboard
Leds of the AX4BS PRO
http://global.aopen.com/about_ContactUs.aspx?Top=Y tell this site your problem they are the offical site for your mtherbboard
Aug 13, 2007 | Acer AOpen AX4BS-V (91.89J11.001)...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
