Question about Microsoft Xbox 360 Console
Error E 82 what is it - Microsoft Xbox 360 Console
    Problem Solver:
  • 7 Answers
E82 error may be that the GPU has overheated and come unseated from the main board. The HDMI cable also may be a reason. also if you have a hardrive try turning it on with the hard drive disconnected.
Posted on Apr 14, 2014
    Habit-Forming:
  • 42 Answers
This is GPU problem, may be overheated, try to contact Mirosoft Support.
Just installed a Rheem RTG-95DVLN. Tried turning it on but all im getting is the # 82 flashing & beeping incessantly! Anybody know why or have any suggestions? Im completely stumped...
According to Rheem trouble shooting, at the end of page 61, error code 82:
Error Code 82
Explanation: Gas Type Control Data Failure; Printed Circuit Board data failure. The PCB has not
been programmed, lost its programming or has failed.
5. If the unit does not operate on initial installation or after replacement of the PCB, then the
circuit board requires programming with the fuel type and altitude chip.
http://hometips.me/Tls/SVC810-Rheem-Ruud-Tankless-Service-manual-2008.pdf
Feb 17, 2016 | Rheem Water Heaters
Error E 82
william, as you and I are probably the only 2 ppl on earth who still have these systems(lol) E 82 is a memory malfunction. It could be fixed by swapping out your controller, as the removable memory is found there. Also, make sure you have your A/V cords plugged in correctly. If you don't it can give you a false rrod.
Apr 14, 2014 | Microsoft Xbox Console
Fujistsu AWY14LSAZ error 82
look on inside of door(s) for diagnostics or manual for the flash codes.need to know what code diagnostic is or give details to what it is doing or not doing, problem with a/c or heat ?
Jan 24, 2014 | Heating & Cooling
Xmit error message
Error in Xmit meaning one of the next options:
• The TI-84 Plus was unable to transmit an item. Check
to see that the cable is firmly connected to both units
and that the receiving unit is in receive mode
• You pressed ON to break during transmission
• You attempted to perform a backup from a TI-82 to a
TI-84 Plus
• You attempted to transfer data (other than L1 through
L6) from a TI-84 Plus to a TI-82
• You attempted to transfer L1 through L6 from a TI-84
Plus to a TI-82 without using 5:Lists to TI-82 on the
LINK SEND menu
Aug 02, 2012 | Texas Instruments TI-84 Plus Silver...
Getting a error code C2 82 on PTG-42PVN / RTG2-42PVN Natural gas indoor
This error code will occur for two reasons:
1. The heater has lost its programming and you will need a new programming chip from Rheem. (866) 720-2076
2. The igniter module is located behind the Printed Circuit board and will need to be relocated.
Apr 10, 2012 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Modem error 82
You can get an 82 error if you are trying to send a fax at the same time one is being received.
If that isn't the case for you, and power cycling the printer didn't help, you are going to have to log a service call.
The fax module may have to be replaced.
Sorry.
Dec 15, 2010 | HP LaserJet M3027x MFP Printer
Error 82 appearing after replacing motherboard
82 means that your programming on the board isn't correct, check for the right altitude chip and fuel type
Jul 30, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
Brother 3240c Error A1 ,A2 and 82
Not sure what 82 code is but A2 and A1 have to do with size of paper possible original to long for size of paper in cassette
Mar 28, 2017 | Brother MFC-3240C All-In-One InkJet...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
