Question about Samsung SGH-E251 Mobile Phone - Black
Where do i insert sd card in cubot gt72e - Samsung SGH-E251 Mobile Phone - Black
Hello Why ist that my zte v795l model phone ask
try changing lower capacity sd card. or maybe the sd card insertion is inverted?
Oct 15, 2014 | ZTE Cell Phones
How can I tell if Straight talk allows Cubot C9 cell phones
You should be able to use your SIM card in any phone as long as the phone is not locked to a network. Whether your calling plan allows data is another issue.
Jun 21, 2014 | ahappydeal Cubot C9 Android 2.3 Smartphone...
Camera says insert an sd card when I already have one. will not let me take pictures
maybe the problem is in your SD card, try to used another SD card. and check if it works.
Feb 14, 2014 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Apr 06, 2013 | Garmin nuvi GPS
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Saying Insert SD Card When Its Inserted
well i had the same problem so i took it to tmobile and the guy on the register inserted a new SD card and he said that my old SD card was ful. so i ask him how can i clear it out and he showed me this lil usb SD card reader that they sell at the store and it was 9.99. but other then that basiclly it means that your SD card us full and you just hook it up to the usb SD card reader and plug it to any computer and go back and clean your files and re-use it again. thats about it. hope that help! : )
Apr 23, 2009 | HTC G1 Smartphone
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
Can not detect sd card
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Oct 07, 2007 | HP iPAQ HX4700 Pocket PC
Samsung SGH-E251 Mobile Phone - Black Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
