Question about Hotpoint Washing Machines
Hotpoint aquarius wmpf 742 pump filter broke
Where can i get parts
SOURCE: hotpoint aquarius 1000 washing machine parts diagram
no current
Posted on Apr 15, 2008
  • 16 Answers
SOURCE: hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Posted on Feb 15, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
SOURCE: I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Posted on Oct 14, 2009
  • 662 Answers
SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is inside the machine. Turn off the power and pull out the machine to get to the rear. Pull out the hose you see going into the wall pipe, lay at floor level or plastic bag to drain out remaining water in machine. Remove the panel at the bottom (2 screws) where the discharge hose comes out. You should see a black concertina type tube coming from below the drum attached by a jubilee clip. The filter is inside. Loosen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in (exactly as you found it) and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at the exact location where you found it, abt three feet up from ground level.
Pl rate me nice for the free help, thnks.
Posted on Jun 04, 2010
I have no hot water on my hot point washing machine Aquarius wmpf 742?
check hose screen if the water is not froze up if that is clean you need a new inlet valve
Jan 27, 2018 | Washing Machines
Washer will not spin it start to but barley moves
my hotpoint wmpf-742 machine,been told bearings have gone,just need to know,if it has a sealed back,if it has,also been told to scrap it??
Jan 19, 2014 | Hotpoint Ariston AW125 Washer
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint 6kg Aquarius , pre wash keeps flashing, so it is not washing......can you help
Check and clean the pump filter.
Remove lower rear panel of washer, remove large black hose on bottom of drum,remove and clean filter inside, alsr remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Nov 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius extra filter
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
23 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
