Question about iRobot Vacuums
No lights at all - iRobot Vacuums
Change brush indicator light
If the light is not glowing it means the brush roll is not spinning. The belt may be stretched and need replaced. The brush roll may be installed improperly. The magnet in the brush roll has to be aligned with the indicator light for the light to work when. The brush roll is spinning
Mar 30, 2014 | Kirby G4 Bagged Upright Vacuum
Green light kirby vacuum
The green light does not affect the performance of your vacuum. There is a small magnet in the brush roll that makes the light glow to show you the brush is spinning properly. If your light worked before you took the vacuum in for service you can look at the brush roll to see if it has been installed properly. The magnet should line up to spin at the spot where the green light is. If the brush is not installed properly or the wrong brush roll is installed the magnet will not line up with the green light.
Mar 03, 2014 | Vacuums
Green light mean
The green light blinking means the belt so slipping. The green light being off means the brush is not spinning at all. The belt needs to be replaced at least twice per year for proper agitation.
Jan 04, 2014 | Kirby Vacuums
Filter queen masjestic vacuum cleaner has a light that should light up when the filter needs changing, it doesnt want to light up. I dont think its burnt.
That is a overhead light not a filter light. If your waiting for the light to come on before changing your filter or haveing the vacuum serviced your going to kill it. Every time you empty the container you should replace your white filter come and ONLY use genuine filter queen cones the aftermarket cheap-os will burn up your vacuum.
Aug 10, 2009 | Bosch Vacuums
Lights on charger do not light and therfore do not charge roomba.
If the charger doesn't light up, it's broken.
Call customer support at 1-877-855-8593. Be sure to have the Roomba and charger with you when you call-- you'll need them.
May 28, 2009 | Roomba Robotic Floor Bagless Vacuum
When i turn on the vacuum it shuts right off. the speckled bag light is on (2 lights under the plug light)
Im going to guess you have an Electrolux Tank. the control valve inside probably went bad. normally i just disconnect it. Do no try to take it apart if you don't know what your doing. take it to a vacuum shop.
May 24, 2009 | Electrolux Vacuums
Do i want the green light on or off on kirby upright
It has nothing to do with the green light. Green light simply indicates that brush roll is spinning. If there is no green light:
1 - belt may be broken
2 - Improperly installed nozzle
3 - wrong brush roll is installed
Properly adjust the nozzle - turn the Kirby on. Keep lowering the nozzle till it touched the carpet and you will hear change in sound. Then lower it by one more click.
Rocky
(GoodVac.com)
Mar 30, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Battery not charging
The charger may be bad. The red light shows that power is applied to it. So usally, unless the light itself is bad, no red light, no power.
Dec 27, 2007 | Vacuums
Vacuums Logo
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
