Question about Frigidaire FEB27S5A Electric Single Oven
Burning smells Frigidaire electric dryer. Burning smells but the dryer can still run. Is this something we can fix ourselves or do we need to call a service tech?
  • 6,784 Answers
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.(this is a fire hazard)
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Posted on Jun 18, 2009
How much to have electronic control board replaced on Frigidaire stove? The readings are too dim. Can we fix it ourselves?
Capacitor C3 a 68uf 35v could be faulty. Check this link out if you wish to attempt a repair - http://www.badcaps.net/forum/showthread.php?t=7902
Jun 30, 2014 | Jenn-Air WW27430P Stainless Steel Electric...
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
Somkey smell comes out from back of toaster oven
smoky smell is usually from the transformers or a bad magnetron. You would need to take off the right cover and visually inspect for something burning.
Nov 02, 2012 | TurboChef TORNADO Electric Oven
My electric Oven keeps tripping the breaker off as well as making a popping noise while doing it and leaving a burning smell. When i turn the knobs to the burner on i hear a clicking noise coming from the...
Hi. YES you most definately have a short. The burning smell is coming from either the wire arcing and thus producing ozone and heat, or the insulation on the wire is being burnt. Take the back off the control unit to expose the wires and see if you can see where the wiring is burnt. It could be a loose connection, or something more serious.
If in doubt, call a professional repairman to check it out.
Earl Marshall
Norse Tool/Equipment Repairs
Sep 22, 2011 | GE JKP15 Electric Single Oven
During self-cleaning cycle we heard a loud pop and it tripped the breaker. Oven and stovetop (ceremic) still work but we smell the same smell from that cleaning cycle like electrical burning? Is there any...
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
John
May 20, 2011 | Frigidaire Ovens
Something went on fire behind the fan,there was a buirning smell and there was orange light coming from behind the fan. Now the oven wont heatr up
That fire and burning smell was your oven element burning out. The element is located directly behind the fan. This is why your oven will no longer heat up.
If you are going to replace the element yourself, there are some universal elements available (try eBay) much cheaper than the OEM replacement parts. You need to make sure it's the same rating though (e.g. 2000W) and is roughly the same dimensions and has the same fitting pattern.
You will also need a service manual unless you know how to get access to replace the element.
Oct 06, 2010 | Neff B1421 Electric Single Oven
Oven smokes and smells like burning plastic
This happened with my oven, happened twice to the same (newer) oven actually. The smell and smoke occurred both with the oven and with the use of burners on stove top. Turned out it was the main line cord which had a split. The first repair they replaced the thermol block and all the bolts holding it into place (for a total of 9 parts) the second time (about a year later) the repairman replaced the line cord and said that it probably should have been done along with the first repair. The smell coming from the oven before the repair was a toxic burning wire or burnt plastic smell. There was also smoke if the oven was left on long enough. The repairman said that the amount of heat to "cook" the connection on the line was at a fairly dangerous level. It was recommended to me by the fire inspector (who was in my unit for annual condo inspections) that it was unsafe and to have it repaired immediately. Hope this helps. Best of luck.
Oct 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Electrical fault on SE250Xuk
It may be something as simple as a crossed or frayed wire. This does not necessarily mean major repairs. Since it is electric, UNPLUG the oven from the wall. Then, take the burner rings out and lift the stove top. You should be able to lift it from the front edge, since it is hinged at the back.
Check the wires under the burner. If these wires are in good shape and the connections are solid, move the stove out from the wall. Remove the back sheet metal panel completely.
Once again, check the wires running the entire length. Make sure all wires running from the knob console to the rest of the oven are not frayed or missing the insulation coating and that the connections are complete and not loose.
If you find frays, some electrical tape should fix it just fine. Loose connections can usually be crimped with a pliers, or if it's a loose electrical connector type connection with a screw, you can remove the connector head and wrap bare wire around the screw, then tighten it down to secure.
If you find nothing wrong when you open it and inspect the wires, then it is possible it needs major repairs. If you are getting a burning smell from ANY electrical appliance, please leave it unplugged until you get it fixed. Nobody likes a house fire in the middle of the night.
Mar 03, 2009 | Smeg SE250XUK Stainless Steel Electric...
Microwave emits a burning smell when on
there is a transformer dont use it and get it serviced
Dec 28, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Frigidaire FEB27S5A Electric Single Oven Logo
100 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
