Question about Ovens
Ge jkp27wov My 2 yr old pushed some buttons on our oven, now the oven cannot be turned on. It displays the word "locked". When I push the Broil button it displays the word "door". But that's it.
  • 21 Answers
Google the company that the oven was made by and search manuals for your oven, then look under features
Posted on Apr 17, 2014
SolutionGuy
  • 331 Answers
SOURCE: GE JGRP17 Gas Oven
Rosanne, he problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN OR TURN IT OFF AT THE BREAKER!
To replace it... Remove the racks and look up at the broiler manifold. You'll see the igniter mounted at the rear (the round thing with 2 wires going to it). You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter, tuck any loose wires as far back into the oven as possible and replace the racks.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Posted on Oct 11, 2007
  • 100 Answers
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
  • 1214 Answers
SOURCE: Jenn-Air elec oven finished self cleaning, door locked,F3 error
Go here to get the manual -
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf
Posted on Jan 22, 2009
SOURCE: my oven beeped and then the display went blank,
The power is going out to the control panel. It is easy to replace the whole controller. Be careful of the key pad cable. it will break easily. The part is $225 for the controller and $172 for the key pad. There are 4 resisters that heat up and a zen diode that fails DZ1. U1 also may fail. My RBD306PDB10 works great now. Do pay attention to the cavity size after re-installing the board.
Posted on Apr 01, 2009
SOURCE: Oven Door Lock
We have a Jenn-Aire self cleaning oven. The cleaning latch would only open if BOTH knobs for the cleaned oven are set to cleaning. Then the latch opened right away.
Start button says push & beep never starts
you have to push the bake or broil button first then set a temperature in it it is not a smart oven you have to give it directions
Nov 05, 2015 | GE JTP15 Electric Single Oven
Oven not heating- both baking and broil elements
It may be possible that the electronic control is bad. On some models there are three relays one for the bake and one for the broil and one for the common. This one goes out and the bake and broil will not work. The control is fairly expensive you may want to have a tech check it out.
Nov 10, 2013 | GE JTP15 Electric Single Oven
I have a frigidaire self cleanig oven and I want to clean it. I pushed the clean button and it lopcks the door but it does not get hot and act like it is cleaning. The oven is over 6 yrs old
These may be dumb questions... but do your bake and broil typically work correctly? What model do you have?
Depending on model, you should be able to press clean, high or low (2 or 3 hrs), then clean again. At that point the door should lock and the bake element should begin to get hot.
Aug 29, 2011 | Frigidaire Ovens
The loc on light comes on when i push any button on my stove i do not know how to get it off
The LOC light indicates the front panel lock is on. This keeps you from starting the oven when cleaning the panel; it also keeps children from turning on the oven. To disable the lock, press and hold Bake and Broil Hi/Lo together for 2+ seconds until SF appears on the display. Then press Self Clean. Then press Start to exit the Special Functions menu.
GE appliance manuals are available from their site. Go to http://www.geappliances.com/service_and_support/literature/ and enter the model number of the appliance. Then click Search.
I hope this helps.
Jun 26, 2011 | GE Profile JTP18 Electric Single Oven
Oven turns on by itself
only thing i could say here is replace the control or clock its real name is an eoc electronic oven control now the part is under a five year warrenty but you have to pay labor and use some one that is authorized for ge warrenty work check your owners manuel for second to five year warrenty and go to ge web site to locate servicer in your area http://www.geappliances.com/service_and_support/service/
Jun 04, 2008 | GE JKP20 Electric Single Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
GE JKP27WP1 Oven Won't Work
Hi Cyrep,
You can fix a suggested fix at the following link:
www.fixya.com/howto/h155060-dreaded_f7_error
Even though you are not getting an error message, they are sometime stored in memory and have to be repeated a number of times before they show up in the display. I have shared this fix with over 1300 folks and most report success. I hope that it works for you too. Please let me know at hutchipop@yahoo.com.
Regards,
Charlie
Oct 15, 2007 | GE JKP27 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
