Question about Britannia Cooktops
Need a manual for a Britannia H-90F-SS-F gas cooktop
When turn on by knob, all 6 burners are sparking ( no problem there).Gas goes on, but ignitor dose not shot off. (keeps cliking). Sandy.
Hi sandybaru,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 09, 2011 | DCS CS-366-SS Gas Cooktop
All 6 igniters continue to click after any one burner is turned on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 30, 2011 | DCS CS-366-SS Gas Cooktop
Missing manual and gas diffuser
May I get the make and model # to help you get the manual.
Also from the gas supply from house to cooktop it should go like this.
gas valve
gas line
regulator
then cooktop
May 31, 2010 | Maytag MGC5430BDS Gas Cooktop
Jenn-Air gas Cooktop fire is low
www.servicematters.com/maytag_library/docs/16010492.pdf service and troubleshooting manual above.
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Need LP conversion kit for kitchenaid cooktop kgcp483kss
Hiya there,
Now I have not read this manual because I would really need to physically see and inspect the make and model of cooker that you have in order to advise you on this exactly, but even so here is a manual I have found for you to read. If however this does not turn out to be the right one for you, please let me know and I will find you the correct manual ASAP.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kgcp483kss.html
I hope this is the fixya for you, and if you haave any problems, questions or comments please get in touch and I will respond accordingly.
Yours sincerely
Oz
Mar 07, 2010 | KitchenAid Architect KGCP483KSS Gas...
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 13, 2009 | Jenn-Air JED8430 Electric Cooktop
Stainless Steel Cooktop - Remove Sealant Spray
try paint thinners , but before you do any thing you need to call the workman to see what brand of glue he has used.or to come out and clean it off for you or to see if thinners will work , it normally does but when i do resturant kichens out any spillages of glue is removed straight away.you will need to use polish cleaner after the thinners to stop any further marks appearing
Feb 17, 2009 | Thermador PC366BS Stainless Steel Gas...
Poor gas flow to GE cooktop
Try a bigger inlet pipe sounds like pipe too small for load .
Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
Cooktops Logo
55 people viewed this question
Top Britannia Cooktops Experts
Paul Carew
Are you a Britannia Cooktop Expert? Answer questions, earn points and help others
