I want to change the channel but in the menu the lock button is in on position we can search only if it is in lock off position but it couldnot work help to change the position
techman
  • 3130 Answers
SOURCE: cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Posted on Aug 18, 2006
  • 556 Answers
SOURCE: Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Posted on Sep 23, 2007
sharptech1
  • 29 Answers
SOURCE: sony trinatron has no menu control, can't auto add channels
YOU NEED TO GET INTO THE CONSUMER MENU AND ACTIVATE THE AUTO PROGRAMM MODE. I BELIEVE WALMART CARRIES A UNIVERSAL SONY REMOTE WHICH WILL ALLOW YOU INTO THE MENU.
APGONZO
30 YR SERVICER
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
Posted on May 13, 2009
SOURCE: zenith h32h38dt 32
I have this TV and a universal remote does the trick
Posted on Jun 17, 2009
Okay, here I am again, wanting to know how to add cable channels to my Hitachi C21 F800S TV. It currently only shows one channel, BET. Please help! Thanks!
1 Press menu button to enter the menu screens for the following optional adjustable settings.choose
2-tune
3-AUTO SEARCH (Activate to auto search & preset receivable broadcast stations)
-if it don't work change this
4Press menu button to enter the menu screens for the following optional adjustable settings.choose
5-tune
6-BAND (change the band system for tuning (i.e. VHF-L,VHF-H or UHF).
if VHF-L don't work try VHF-H or UHF and restart all over
good luck
Oct 05, 2014 | Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
Sub-Channels
Here is a link to a list of older TalkAbout user manuals. Use the pulldown menu to look at various models. In general, most of them program similarly by using the menu button to select the feature and the PTT button to lock in the change. http://www.giantintl.com/motorolafrsold.htm
May 26, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
May 13, 2009 | RCA F25216BC 25" TV
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
