Question about Neff 31 in. T1872 Electric Cooktop
My hob is locked and won't switch on
I have tried to hold buttons down and all that happens is a red flashing e appears across the top of all my switch on points
HOW DO I UNLOCK MY SCHOTT CERAN CERAMIC HOB
l means locked hold two left buttons at same time or the two right buttons or the bottom two buttons or top two buttons should solve your problem you have to do it prety quick or the computer thinks a child is trying to turn on the appliance
Jul 28, 2014 | Whirlpool W5CE3024XS 30" Electric Cooktop...
How to un lock
My hob unlocks with that I turn on the hob and the the L appears, then I hold down the lock button until it disappears then I push the STOP/GO button.
Jan 22, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Jun 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob.
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
THE LOCK INDICATOR FLASHES WHEN THE ''ON'' BUTTON PRESSED--TRIED ALL COMBINATIONS OF BUTTON PRESSING TO NO AVAIL--ONLY OTHER INDICATIONS ARE THE ''e'' INDICATORS FLASH FOR ALL FOUR HOBS
hi my name is mark have tried to hold the on button down for 10 seconds. sometimes that unlocks controls.hope that helps.
Mar 16, 2009 | Cooktops
Got a diplomat ceramic hob with no instructions
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
Jan 14, 2009 | Cooktops
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
Neff 31 in. T1872 Electric Cooktop Logo
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
