Question about Powerglide Drills
Powerline comtrend permanent red light - Powerglide Drills
5 Suggested Answers
damonumber5
  • 340 Answers
SOURCE: i have 2 comtrend dh-10pf
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Posted on Mar 09, 2009
SOURCE: comtrend powerline ethernet adapter : power cuts
nope mines the same
Posted on Oct 22, 2010
SOURCE: Can not turn my comtrend powerline adapter of standby
i have the same problem,and i'm working on it,most probably a faulty capacitor in the power supply,i will let you know.
Posted on Dec 28, 2010
multilinkent
  • 739 Answers
SOURCE: Comtrend 9020 connection problem Unable to
Hi..
look at the problem you describe. Internet activity is most likely normal, but can not send a good Powerline Standard or High Definition (HD) movies
I said like that because the red led error is when the connection is less than 4Mbps, normal Internet activity Powerline possible but can not send good films Standard or High Definition (HD) movie
see in the picture below
try to do reset to default again
ways to do factory reset
Download manual guide for your reference
CLICK HERE TO DOWNLOAD
regards
hope this will help you
Posted on Apr 02, 2011
Comtrend powerline adapter
are you saying the connection between the two powerline devices is dropping? try moving the wireless adapter to a power outlet a little closer to the base router, they might be just a little too far away from each other right now. even though it worked for a long time, the device might be getting interference from some other electrical device on the line which causes it to act up.
Dec 14, 2013 | Edimax HP-2002NCK 200MBps Powerline...
I have a pair of Comtrend 8902 which have been working well for a couple of years. However, as of last Saturday, the AP LEDs are all flashing red. Holding down the standby button does stop the flashing,...
I don't have those particular ones, but I have added more units to an existing pair of powerline adaptors. They are not paired, but simply configured onto the network you have set up. Once you have the initial pair set up it should be possible to add as many others individually as you need.
hope ths helps...
May 16, 2011 | Computers & Internet
I HAVE BT INFINITY BROADBAND - WORKING OK - I AM USING IT NOW VIA ETHERNET CABLE TO LAPTOP. HAD COMTREND POWERLINE 902 NETWORK SET UP AND WORKING. WAS ABLE TO ADD 2 MORE ADAPTERS - OK. BOUGHT 2 MORE AND...
The modem is probably still looking for the MAC address of your laptop at this point.
You need to unplug the modem AND the 902.
Power up the modem first and give it a minute to let the lights settle then power up the 902
Once the 902 is powered up and it's lights have settled down, start powering up devices that connect to the 902.
You may be surprised that this is all it takes!
Mar 12, 2011 | Comtrend Computers & Internet
Turned my ethernet adapter off on the upstairs one and back on to find that there is no green lights anymore, just a red light on status. Then did the same with the downstairs one and they both have a red...
Powerline adapters are generally not durable. You can try to reset the power adapter by pressing the reset button located on the device itself. If it still gives you a red light than call the manufacture and get it replaced.
Jul 15, 2010 | Powerline Ethernet Network Adapter
Feb 18, 2010 | Computers & Internet
Do I have to use a xbox adaptor to use xbox live.
no you can also link the yellow cable you got in the box into the modem of your internet and play like that
Dec 28, 2009 | Microsoft Xbox 360 Console
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
Hope this helps.
Jan 28, 2009 | Computers & Internet
Drills Logo
29 people viewed this question
Top Powerglide Drills Experts
Are you a Powerglide Drill Expert? Answer questions, earn points and help others
