Question about Exercise & Fitness
Reebok treadmill z9 error e-01
After count down the treadmill starts but stops immediately how can we reset this
SOURCE: Need a Reebok treadmill repairman.
I can fix it for you. Just post it to me in London. Hope this was of help!
Posted on Mar 02, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
bwinton
  • 83 Answers
SOURCE: the belt is sticking on my treadmill reebok TR3
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Posted on Sep 24, 2010
I have an E-01 error message on my reebok z9'machine
You have to check the speed senor for its positioning.
If you wish to get some details about treadmill error codes and solutions ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 17, 2016 | Reebok Exercise & Fitness
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
Oct 23, 2016 | Reebok Exercise & Fitness
Reebok z9 treadmill beeping with error e01,this happened once before then went ok,driving me mad any help please
Try to check the Speed sensor. Check for its aliment also check is there is any dust accumulated on it .
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 13, 2016 | Reebok Exercise & Fitness
Knocking sound on Reebok z9 treadmill. Why does it happen? Did i ovover tighten the belt? Its brand new but knocking starts as it gets quicker. Also is suppose to go to 16kph but only goes to 10kpm. Any...
What is the frequency of the knock? Is it every second, few seconds, or very fast? This can tell if it has something to do with the track or the motor.
Feb 01, 2015 | Reebok Exercise & Fitness
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
My Z9 treadmill will not turn on... i've flicked on the power swtich and the switch on the machine but it wont sstill come on. what can i do?
Our Z9 has just done the same, switched on the power but it doesn't turn on. Was just wondering if you managed to fix yours and if so how?
Thanks.
Sep 12, 2013 | Reebok Exercise & Fitness
E2 appeared in monitor of reebok z9
adjust the speed sensor, clean it, tight the plug very well, see the diagram
adjust the reed switch, clean it, tight the plug very well, see the diagram
test the input voltage motor, if there are the motor need repair
4) test the output board, for input voltage motor, if there are NOT the board is faulty. see the diagram
.God bless you
Oct 10, 2012 | Reebok Exercise & Fitness
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
Feb 11, 2011 | Reebok 8000 ES Treadmill
Brand new Reebok v6.80 treadmill, trouble on start up!
I just had the same thing happen to me with the same treadmill. I called Reebok and they had me remove the motor hood. Sure enough, the bolts holding the motor had completely sheared off and the motor was lying loose in the bottom of the treadmill. They are sending a new motor and bolts and a technician to install them. They said it was probably dropped hard during shipping.
Jan 23, 2009 | Reebok New York Giants Eli Manning Jersey
Exercise & Fitness Logo
82 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
