Type of font used fax confirmation - Office Equipment & Supplies
How do I make my font and text size bigger?
If you want to make font and text larger in a Word document, just look at the taskbar and click font pull-down window (usually the default is Times Roman) and pick whatever font you want, then click the pull-down window (usually the default is 12) and pick a larger size.
Or you need to make a display adjustment. Click Start, Click Control Panel, Click Personalization, click Display Settings, choose Resolution up or down which will adjust icon and font size on your computer.
Or click start, Control Panel, Personalization then:
  • In the left pane, click Adjust font size (DPI). If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  • In the DPI Scaling dialog box, do one of the following:
    • To increase the size of text and other items on the screen, click Larger scale (120 DPI)-make text more readable, and then click OK.
    • To decrease the size of text and other items on the screen, click Default scale (96 DPI)-fit more information, and then click OK.
    To see the changes, close all of your programs, and then restart Windows.
  • Jan 01, 2011 | Computers & Internet
    I recently purchased a refurbished Dell. The computer's main font color is purple instead of black. Can this be changed?
    Please let me know which operating system in installed on the Computer. Yes, it's possible to change back to it's default (O.S default) font color, but the way to change is little or more different.
    I would also like to confirm which font looks Red, the text (names) on the desktop or the font's when typing in Microsoft Word or etc.. If you could somehow upload the screenshot, that'd be much appreciated.
    Awaiting.
    Nov 09, 2010 | Computers & Internet
    NEED TO CLEAR MESSAGES OFF ANSWERING MACHINE
    When the answering system is full, [FL] is displayed on the base, and the system announces "No remaining time."
    To delete the old messages.
    1) Press the [play/stop] key to review your messages.
    2) Press the [delete,ont Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} ø] key( located below [ >| ] button or at the right side of [ ^ ] button )anytime during the message to delete.
    3) You will hear a confirmation tone and the message is deleted.
    You can also delete all the messages.
    1) Press the [ø] key in standby mode.
    You will hear an announcement “To delete all messages, press delete again.”
    2) Press the key [ø] again.
    You will hear a confirmation tone and [ 0 ] is
    displayed on the base. All the messages are deleted.
    When you try to delete all messages without first listening to your new messages, you will hear several short beeps followed by an announcement “Please playback all messages.” This means it protects you from accidentally erasing messages you have not yet reviewed.
    hope it help ; )
    May 27, 2009 | Lands Phones
    IBM Wheel Writer 6 font help
    Hi:
    There is no manual way to change the pitch on any IBM Wheelwriter. If you want a different pitch you need to change the printwheel.
    Andrew
    May 08, 2009 | Office Equipment & Supplies
    Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
    To get confirmation page do this:
    1. On the control panel, press Setup ( ).
    2. Use the arrow buttons to select Reports, and then press OK.
    3. Use the arrow buttons to select Fax Reports, and then press OK.
    4. Use the arrow buttons to select Fax Confirmation, and then press OK.
    5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
    6. Press OK to save the selection.
    To iclude first page with report:
    4. Use the arrow buttons to select Include 1st page, and then press OK.
    5. Use the arrow buttons to select On, and then press OK to confirm the selection.
    Mar 25, 2009 | HP LaserJet 4 plus Printer
    Confirmation
    By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
    1. Press the right arrow until Reports appears in the display, press the checkmark.
    2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
    3. Press the right arrow until Print Report appears in the display, press the checkmark.
    4. Right arrow to the option of choice, press the checkmark to save the change.
    FAX call report options
    • Send Fax Only - a confirmation sheet will only print when a fax is sent
    • Never - no fax confirmation sheets
    • Every Error - default setting
    • Send Error - a fax confirmation prints when the fax transmission encounters an error
    • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
    • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
      Thanks, Joe
    Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
    Confirmation page
    You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
    Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Fax confirmation set up
    document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
    Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
    Fax Confirmation Sheet
    Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
    14 people viewed this question
    jasbo
    jasbo
