Question about Maytag Washing Machines
My new Electrolux Hydrosonic washing machine has to be manually filled with water as the automatic feeder is too slow and an error occurs.E1. So I have connected a pipe to an adjacent sink . The machine recently was overfilled by my illiterate maid and now is not working. It appears water has travelled where it shouldnt. The machine was off when it was filled. Please advise if this problem can be rectified
SOURCE: Ariston Washing machine A1636 - Flashing lights
always reset your machine ;turn your dial to the end of the cycle [ the dot] it should flash 3 times quickly, then turn off the machine and on again. then start washing again ...hopefully..worth a try.
Posted on Aug 15, 2007
  • 1462 Answers
SOURCE: banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Posted on Sep 17, 2008
  • 1462 Answers
SOURCE: Hotpoint Washing Machine Model # VBXR1060T4WB Filling Problem
problem could be the pressure stat which is a switch which detects water level or the pipe leading up to this switch or the air chamber the pipe goes to.
take top off. locate the pressure switch - has a small diameter pipe going to it. remove pipe and fit a similiar one. put on fill and pressurise this pipe by mouth and water fill should stop. if it doesn't, then switch is faulty.
if this is ok, examine carefully the small diameter pipe for splits and blockage. also check the air chamber for build up of gunge
Posted on Nov 16, 2008
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What is E1 error code
    The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
    Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
    Error during start for samsung automatic washing machine
    E1 = Not filling in allocated time
    This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed.
    Nov 28, 2012 | Washing Machines
    How to fix samsung washing machine model TORNADO 7.0kg WA90B error
    E1: Water Supply Error
    -Display Shows 'E1'
    -Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
    -To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
    -The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
    Nov 01, 2012 | Washing Machines
    Error E1 samsung washing machine model TORNADO 7.0KG WA90B
    -Display Shows 'E1'
    Keep me posted!
    Electrolux ewf1282 wont fill with water
    If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Jul 10, 2011 | Washing Machines
    E1 Code - tried fixing it according to manual still won't work
    The error code E1 = Water supply error -Not enough water entering the W/M.
    Try check water supply line is on and not have any kinked.
    Mar 21, 2008 | Samsung WF337AA Front Load Washer
    Washing Machines Logo
    22 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
