Question about Siemens Gigaset 4200 Cordless Expansion Handset
Siemens Gigaset 4200 open - Siemens Gigaset 4200 Cordless Expansion Handset
CORDLESSGURU
  • 106 Answers
SOURCE: Siemens Gigaset 4200
Hello, Yes this happens when you add a additional handset to the system when all the intercom numbers are full. When registering a new handset, it "kicks out" on of the other handsets when it registers. The only way to correct that problem is to default your base and register each handset again, one by one. You won't lose your handset settings, but you will lose your messages and greetings, so check them before doing so. To default your unit, get all your handsets and go to your base. Unplug the power from your base. Hold down the page/registration key on the bottom of the base and keep it held down while you apply power to the base. After applying power, keeping the button down, count to 20. Then release the button and get each handset. Register each handset, and they will number themselves 1 through 4. If you need additional assistance, service or need to purchase another handset or base (you can register each handset to up to four bases to increase your range, this is unique feature in the cordless industry), you can go to www.cordlessrepair.com for all your Siemens cordless needs. Good Luck ! Let us know how it goes, we have a testimonial page on the website for people to leave comments on the technical tips or assistance they receive from our technicians.
Posted on Jan 11, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 3230 Answers
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
Posted on Apr 02, 2010
e-Guru
  • 3917 Answers
SOURCE: Need to replace a Gigaset 4200 extension. Since
Please check the bellow link if it helps:-
http://www.barclayent.com/Cordless/cordlessphonerepair.htm
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 30, 2010
  • 20 Answers
SOURCE: Siemens Gigaset 4200 Cordless keep searching for base
The handset should be returned to the charging station, let it set for a few seconds. If this is a satellite phone, make sure the main phone "base unit" is connected to phone outlet and plugged in. After the phone has established its physical connection with the base again you can remove it and use it like normal.
Posted on May 18, 2012
How do I set up voice mail box on gigaset 420
I am done helping sightless ignorance Again, for the last time
Read the INSTRUTIONS
If you cannot, Move to California or New York City and worship at the Alter of O'bamma
Nov 17, 2014 | Siemens Gigaset 4200 Cordless Handset &...
How can i configure siemens gigaset 504 agu for bsnl broadband connection
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Search siemens gigaset 504
They have very easy setup instructions
http://etisalatsupport.blogspot.com/2012/07/siemens-gigaset-504-router.html
Save file for next time.
http://www.etisalat.ae/eportal/en/images/docs/userguides/modem&drivers/Setup-ADSL-Siemens504AGU.pdf
Oct 25, 2012 | Computers & Internet
May 18, 2012 | Siemens Gigaset 4200 Cordless Expansion...
Base on the 2 phones both keep flashing base. tried to swap them over, turned on and off, but nothing
try replacing the batteries. Sometimes the flashing is just because it's not charging them.
I believe the Siemens uses standard rechargable AA batteries?
Jun 11, 2010 | Siemens Gigaset 4200 Cordless Expansion...
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Siemens speedstream 4200 modem need any driver?
http://gigaset.com/shc/0,1935,us_en_0_14791_rArNrNrNrN,00.html GO HERTE RICHARDM69
Nov 18, 2008 | Siemens SpeedStream 4200 (13A4200001)...
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
My phone can not reset
I am having the exact same issue! I tested the jack with another phone and it works. It is something in the phone. I suspect there is a "clear" button somewhere - but can't find the owners manual.
Dec 13, 2006 | Siemens Gigaset 4200 Cordless Expansion...
Siemens Gigaset 4200 Cordless Expansion Handset Logo
126 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
