Question about Bulova Watches
Mega block 96805 - Bulova Watches
How can I set the time of this RADO Jubilee Esenza watch?
hay hi i found a pdf file with how to set time,date for all there watched link below no rar file. just pdf called manual.pdf hope it helps you. MEGA
May 21, 2016 | Rado Watches
Why don't my browser open web pages i want?
Check your security settings , some pages are blocked unless set to allow , update browsers some browsers will fail to display pages if browser is not compatible with page . Network : corporate networks block some web pages if it is your own home network this most likely won't apply
Jun 12, 2014 | Watches
If someone has blocked me in datehookup.com can i get passed the block
mcdevito75 here, Chances are no, you won"t be able to get past the block. Simply move on in that particular website. The trouble you can get into isn"t worth it. Hope this helped.
Jul 14, 2010 | Audiovox Watches
I HAVE JUNGHANS MEGA SOLAR CERAMIC 018/1503.44 NO INSTRUCTIONS
Try this link. http://www.junghans.co.uk/downloads/neu.pdf scroll dow as the english part is some pages in to the booklet.
Regards
Dave.
Mar 30, 2009 | Watches
Link removal
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Dec 29, 2007 | Fossil AM 3688 Wrist Watch
Watch band
Tools:
Procedure:
Dec 25, 2007 | Fossil AM 3688 Wrist Watch
Fossil Brazelet
Tools:
Procedure:
Dec 07, 2007 | Fossil AM 3688 Wrist Watch
Watches Logo
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
