CANON E510 - WHEN PAPER IS AVAILABLE IN TRAY, ERROR IS DISPLAYED AS 'PAPER NOT AVAILABLE' AND NOT GETTING PRINTED
SOURCE: wont print
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
Posted on Nov 05, 2007
  • 3 Answers
SOURCE: PRINTING PROBLEM WITH CANON IP1880
please try
http://canon-resetter.blogspot.com
http://epsonresetter.blogspot.com
Posted on Mar 19, 2008
  • 54 Answers
SOURCE: No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Posted on Mar 21, 2008
SOURCE: Canon PIXMA iP5300 InkJet thinks paper output tray is closed (it isnt) and won't print!
It was rather easy to figure out how to pop the silver plastic outter casing off, but now that I have it off I still can't seem to identify where the switch that signals the paper outter tray is.
Posted on Sep 17, 2008
damien729
  • 221 Answers
SOURCE: Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Posted on Jul 29, 2009
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
I have canon copier ir c2100,i cant print becouse when ever i try printing it displays as out of paper but there is a lot of paper too what do i do
Try to put paper into the manual feed tray and let it print. I would check to see what you default tray is set to... It may be to the manual feed tray and make sure you have the correct paper size for your paper trays
May 16, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
Printer Error message : Printer Error has occurred. 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Dec 21, 2010 | Canon Office Equipment & Supplies
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Will not print
go to this page: "http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651#SupportDetailAct"
seems to be related to paper jams or wrong size of paper being placed in the front tray. if loading odd (e.g.: credit card sized), paper sizes, they need to be loaded into the rear tray.
good luck!
Jan 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
13 people viewed this question
k24674
jasbo
jasbo
