Westinghouse lt809s The agitator goes one way only? What's needed to fix?
4 Suggested Answers
  • 29 Answers
SOURCE: My westinghouse lt809s is very noisy while
Then you probably either need to clean that bearing assembly up or go to an appliance parts center and take the model number with you and purchase a new bearing and pulley assembley.. Also check for worn belt.
Posted on Mar 12, 2010
Testimonial: "Thanks. I think your suggestion is spot-on!"
SOURCE: My westinghouse washing machine LT809s
It means Low Level. Your water level is too low. Your machine isnt filling up properly or the water is being siphoned out as it fills which means your drain is lower than your water level. or your drain does not have an air lock in it any more.
Posted on Jul 27, 2011
SOURCE: My washing machine westinghouse LT809s
We moved our machine going perfectly fine untill then. Now displays a HC sign eater will fill in machine on any cycle then empty out at the same time so doesn't fill at all. Help please
Posted on Jan 03, 2012
WHAT is causing my Westinghouse Top Loader Washing Machine model LT809S to only agitate in one direction ??
problem with the direction control relay or power board
call a technician to diagnose properly
Jul 21, 2015 | Westinghouse Washing Machines
My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
Jun 12, 2011 | Westinghouse Washing Machines
My westinghouse washing machine LT809s keeps beeping at me and displaying the error code LL?
Mar 31, 2011 | Washing Machines
My westinghouse lt809s is very noisy while spinning. The part under the agitator looks 'corroded' and probably needs to be replaced. Suggestions?
Mar 12, 2010 | Washing Machines
32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Oct 23, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Removing agitator
Sorry, I can't help you. This is the area for asking questions about computer monitors, not washing machines. You clicked the wrong link.
Look at the top of the page, click the Westinghouse link and then on washing machine. Enter your question there.
Mar 28, 2008 | Westinghouse L1975NW Monitor
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
