How many kilowats is a hoffwel kfr-61gw - Heating & Cooling
2 Suggested Answers
  • 289 Answers
SOURCE: Hoffwell Air Conditioner KFR 61GW turned itself off
You may want to check the thermocouple. It should be located on the front coil. You have to remove the front cover to see it. However, close the vents and try it. If is overly humid that front coil will just condense all available outside humidity and the thermostat will be frozen. Pull the thermo stat away from the coil so it is not being frozen. Replace TC after that test Good luck.
Ash
Posted on Dec 08, 2009
What does it cost to run a sb40 pool each day?
look on side of motor for kilowats find out cost per kilowatt and x by time running
Mar 27, 2016 | Pool & Spa
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
When i change the batteries the remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
After battery change, it should be set up with set-up codes to your device again. Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Jun 02, 2014 | Soleus Air P-KFR09-05-ID Remote Control...
Hoffwel Air Con Remote
I have found 1/2 the time there is some type of liquid that has gotten inside the remote and not dried but become a film that will make connections as described, corrosion on the contacts and battery also will cause this on the boards,wipe the board down with acetone, otherwise its damaged and needs replacement.
Jun 28, 2013 | Heating & Cooling
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I have a hoffwel Air conditioniner and the remote is broken Hoffwel went out of business years ago where can I get another remote that will operate it Thank you
Welcome to no spares, I have tried for over a year to get a remote but none around so atended autions till l found one that worked with air con and barted for it as a/c didnt work but alas that control packed up.
All is not lost, local a/c man can get a multi manufactor one and "tune" it in for you at a price...l was quoted $180. So try your local A/c man.
Aug 28, 2011 | Heating & Cooling
Average kilowat consumption of a Toshiba Qosmio
Minimum (everything off and/or on minimum): 31.8 Watts
Idle (max. brightness): 42.1 Watts
Maximally (full load inclusive. WLAN): 64,8 Watts
May 25, 2010 | Toshiba Computers & Internet
Ash
Dec 08, 2009 | Heating & Cooling
Kfr 24w condensor will not run
Check the contactor to see if the contacts are stuck or welded together, if not check to see if you have 24 volts to the contactor, if you do then the thermostat is not opening.
May 17, 2009 | Comfort-Aire BHD-301 Dehumidifier
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
