Question about Icom IC-R8500 Base Scanner
IC-R8500--Display is flashing continuously--no receive
Reset CPU
Checked all internal inter board cables
    New Friend:
Re: IC-R8500--Display is flashing continuously--no...
First check the tape cables from Conv Unit and Rf unit to main unit.
Second find if the PLL ICs lock (MC145190) check voltage at pin 2 (LO) ~4,5Vdc in PLL Unit.
Third find If the (PQ30RV31) voltage ADJ in main works.
Posted on Apr 15, 2008
0 characters
3 Points
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
NO audio signale
l would first check for audio from the external speaker connection which most have.
Dec 12, 2012 | Icom IC-R8500 Base Scanner
My scanner will not transmit digital trunking channels
There may have been a change in the digital transmitting system
Oct 19, 2012 | Radio Shack Pro-2096 Base Scanner
I have a icom ic-r5 scanner that will not start
Check the battery contacts. Sometimes there may be corrosion on them from old batteries. You can also check the contacts that connect the logic board to the battery contacts. There are two small Philips screws in the battery compartment. Remove them and the back cover comes off. You can check the contacts on the inside of the back cover and see where they make contact with the logic board. Make sure all contacts are free of corrosion. If it still will not power up. try a CPU reset. While holding down [FUNC] and [V/M], turn the power ON to reset the CPU.
Nov 02, 2010 | Icom IC-R5 Handheld Scanner
My pro 94 scanner shows the code luired when turned on. How do I fix this?
I'm guessing that the display shows "wired" and not "luired." This mode, along with the code, is supposed to clear when the computer programming cable is disconnected. If you don't have a cable connected, your only option is to RESET the scanner to its original factory settings. Just a caution: resetting the scanner will erase/delete all programmed information -- you will have to reprogram all of the data that you've previously entered. To RESET the PRO-94:
1. Turn the scanner OFF.
2. While holding down the 2 and 9 keys, power the scanner ON. The message "CLEAR" will flash for about 5 seconds while the scanner resets.
NOTE: Do not turn the scanner OFF until "CLEAR" stops flashing.
Bill B.
Listening in since the 60's
Oct 27, 2010 | Radio Shack Pro-94 Scanner
I have been using the IC-R5 for a few years now with no problems except when using it during the summer. If the weather is hot, after being switched on for a period of time the scanner just starts to bleap...
The occilator that "locks" the VFO (like a clock signal) is gong out of range. The higher temps are affecting the temprature controlled occilator. I would send the unit to ICOM for repair.
Jun 21, 2010 | Icom IC-R5 Handheld Scanner
I need frequiences for local police departments for my scanner valdosta ga 31601
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Apr 04, 2010 | Icom IC-R8500 Base Scanner
Power inverter on ic-r8500
wow thats a great radio, pack it up and send it to me.(just kidding)you might want to contact icom and talk to their techs about this one. congratulations on having one fine radio, it is worth a quality repair,ive wanted to take one of those apart for years lol
Jul 16, 2008 | Icom IC-R8500 Base Scanner
Audio problelms
Bad Solder Connections on The Main Board(Look for Ring Breaks)
Jun 10, 2007 | Icom IC-R8500 Base Scanner
Icom IC-R8500 Base Scanner Logo
1,168 people viewed this question
Top Icom Radio Scanners Experts
Robert McClure
Are you an Icom Radio Scanner Expert? Answer questions, earn points and help others
