Question about Sanyo Televison & Video
Sanyo 14'' crt tv. clear picture but no sounds, i replace the audio ic but still the same no audio.
    Top Expert:
  • Sanyo Master
  • 74,251 Answers
Have you checked the input voltage to Audio IC? Checked the speaker/s? Check these too. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 14, 2014
Sound isn't coming through on the sanyo ds315
Check its speaker/s first. If found OK, check and replace damaged component/s at its audio output stage circuit. Keep an attention to the audio output IC. For more information go to http://electronicshelponline.blogspot.com/
Nov 26, 2013 | Sanyo DS31590 31" TV
No audio on sanyo ds31520 after replacing vertical IC.
Replacing vertical output IC won't poise this type of problem. Check the voltages at the audio output section.
Jun 22, 2012 | Sanyo DS31520 31" TV
I HAVE A SANYO MODEL 31590 NO PICTURE SOUND JUST A LINE IN THE CENTER
hi..hope this help you....a horizontal line in the center is an indication of defective vertical IC...its looks like a tab w/ 10-12 pins and has heatsink...your TV would works out fine when you replace the IC....but its better if let a technician replace this....pls. don't forget to rate and vote....thanks...
Feb 17, 2011 | Sanyo DS31590 31" TV
Sanyo TV Chassis Series AC5-C20 no sound
check power supply to ic,, it will be 12v from smps..may be fusable resistor has gone
Mar 21, 2010 | Sanyo DS27910 27" TV
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
Sanyo DS35510 35" has picture but no sound. Checked all audio under menu section, turned both tv and cable up really loud, made sure both cable and tv wasb't on mute and still no sound.
You may have a malfunctioning audio output IC. I would suggest checking the input to the IC and seeing if you have an audio signal at the input. If so then the output IC is defective, if not continue checking the stages of audio going back from the output IC.
In addition check your speaker connections, and internal cabling.
This can cause this problem also.
Thank you
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 06, 2009 | Sanyo DS35510 35" TV
We are getting a picture but no sound.
First go to menu make sure audio is not turned off CK speaker . then audio output IC.
Feb 15, 2009 | Sanyo DS31520 31" TV
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Sanyo television-model-DS25530
have you treid the menu settings and looked at the rear for internal /external switch on the rear of set if yes to both possible audio ic.
Aug 14, 2007 | Sanyo AVM-3259S TV
Televison & Video Logo
21 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
