Question about Brother IntelliFAX 4100 Laser Fax
How to fix code 71 - Brother IntelliFAX 4100 Laser Fax
I don't know
Posted on Jun 18, 2009
What is TSB 71-65-66 and how to fix it?
DTC 1676 [Archive] - FirebirdV6.com/CamaroV6.com Message Board
forum.camarov6.com > ... > Technical > Advanced Engine
Mar 6, 2003 - 9 posts - ‎4 authors
71-65-66 NOV 97 Engine Controls - EVAP DTC's P1665 & P1676 Added " that is from alldata as a TSB i dont know what "EVAP" is though.
Find Technical Service Bulletins for your 1998 Buick ...
tsb.govwebs.com/k-vin-v638l-lesabre-buick-1998-10199.html
Free Technical Service Bulletin and Recall Titles for 1998 Buick LeSabre V6-3.8L VIN K ..... 71-65-66, NOVEMBER 1997, Engine Controls - EVAP DTC`s P1665 ...
Trouble Code - AutoZone
www.autozone.com/.../Buick.../_/P-0996b43f8036fc4e
AutoZone... power circuit is open (check ENG EMISS fuse). Purge solenoid is damaged, or the PCM has failed. TSB 71-65-66 contains a repair procedure for this code ..
Nov 24, 2015 | 1998 Buick Century
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up
Jun 29, 2008 | Brother Office Equipment & Supplies
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
1994 4Runner V6 (non-4wd) error code 71
2.4L code 71 - EGR Gas Temp Sensor
3.0L code 71 - EGR Gas Temp Sensor
There is a test procedure to tell if bad sensor or wiring problem, can email diagram to you if like need an email address to send to
Feb 08, 2010 | 1994 Toyota 4Runner
Telewest codes for 6/10/09
00 = C2 B5 BE 41 0D 9B C5 7C
01- 6d ea 8e 97 6a aa da 71
Oct 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
1995 geo prism code 71
The 71 code is related to the EGR system.
Underneath the intake manifold, it bolts on at cylinder # 4. or first from the drivers side. It is found right under the EGR Modulator. Disc like device with two vacuum line on the pasenger side and one vacuum line on the driver side. Best way to get to it is to remove the intake manifold. you need to replace it to get the problem fixed
Sep 14, 2009 | 1995 Geo Prizm
Malfunction code C00 71
These codes are generally related to the toner motor, if you have changed the toner lately.Check the install of the toner cartridge, remove it and reinstall it, close up the machine and try again.
Hope this is of som help.
Ed
Apr 26, 2009 | Minolta Office Equipment & Supplies
Brother MFC 8220 Error code 71
that code indicates that your laser unit has gone bad. no way to reset or repair without a tech replacing the laser unit itself.
razors
Mar 18, 2009 | Brother MFC-8220 Fax
Error 71
fault with the fusing unit
try changing the fuse
see
http://ezinearticles.com/?Xerox,-Okidata-Error-Codes-and-How-to-Fix-Them&id=1053652
Jul 18, 2008 | OKIPAGE 14ex Led Printer
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
Brother IntelliFAX 4100 Laser Fax Logo
64 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
