Question about Baby Gear
What are the eight legs of a spider called
Please give me the names of the spiders legs in ictures
DAD5bbbbg
  • 111 Answers
SOURCE: inner cv joint disassembly
If you are changing the CV joint with shaft, after getting the outer end of the shaft out of the hub, Take a small pry-bar and pry the shaft out of the tranny.
Posted on Mar 14, 2009
SOURCE: Spider web behind front of screen
First remove the speaker panel, no screws, it just pulls off. Then remove 8 screws, you will note the 4 other screws that are not attached to the screen itself, do not remove those. Then pull out a little from the bottom, not too much or you will break the screen then pull up. When I did it the left side came loose right away, but then I had to use a screw driver to pry out the right hand side. The sides are actually in a simple pressure slide, a little prying with the screw driver loosen up the sides. When you put it back together, you put the top rail in first, press in the sides and replace the screws. Job done and you saved yourself a lot of bucks.
Bob in Belleville Ontario, Canada
Posted on Apr 08, 2009
SOURCE: spider vane adjustment NG76AZ TELESCOPE
Watch this video that explains COLLIMATION-
http://www.andysshotglass.com/Collimating.html
Posted on Dec 26, 2009
  • 572 Answers
SOURCE: Broked Spider on a Kenmore Elite H3 washer.
u can buy them seperatly. the shaft is part of the basket
Posted on Feb 07, 2010
ercupa190
  • 12223 Answers
SOURCE: REAR DRUM BASKET SPIDER
you have 3 options :
1) http://www.geappliances.com/service_and_support/ 2) www.repairclinic.com 3) www.appliancepartspros.com
God bless you
Posted on Oct 01, 2012
What is a funnel spider and is it dangerous
Australian funnel web spider Can't believe people waste time logging in to Fixya to ask a bone question when they can just search google
Sep 19, 2014 | Washing Machines
I have a spider in my living room looks yellow and where its legs bend there is black circles which i prosumme is there knee has yellow upper body and yellow lower body with a black dot in both top bottom...
It sound like a common Garden Spider. The spider species Argiope aurantia is commonly known as the yellow garden spider,[1][2]black and yellow garden spider,[3]golden garden spider,[4]writing spider, or corn spider. It is common to the contiguous United States, Hawaii, southern Canada, Mexico, andCentral America. They have distinctive yellow and black markings on their abdomens and a mostly white cephalothorax. The etymology of its name means "gildedsilver-face". Males range from 5-9 mm (0.20-0.35 in) females from 19-28 mm (0.75-1.10 in). Like other members ofArgiope they are considered harmless to humans.
Aug 25, 2014 | Home
What is an arachnid
Think spiders
All arachnids have eight legs.
Jul 01, 2014 | Toys
A black spider about 1 inch with a large sack on its back
catch it under a glass and release it OR kill it ps I think the "sack" is called the abdomen.
Dec 24, 2013 | Optics
Spider Bite
i think you might need to send him to the hospital and tell everythings to the doctor because i bet the spider bite Caused to hi lose 20kg it might be a viurs your son might be in danger sent him to the hospital for checkup and if the ploblem contuine ask the doctor to scan his body for viurses it might help too.Good luck ! May God Bless You and your Son!
Dec 09, 2013 | Computers & Internet
A black spider with two lines of white spots on its back and orange spots along the legs
Why is this about Telescopes? Any ways, If we want to talk Spiders, Lets Chat..
Need a little more info like what State you live in, However here's a Website with a fast list of pictures and the name of spiders on it just for you, Enjoy.. BCB...
http://www.insectidentification.org/spiders.asp
Oct 21, 2013 | Optics
What is a spider indicator?
There is no "Spider Indicator", but the fuel injection system is sometimes referred to as a spider assy because it has a central unit with individual legs (hoses) going to each cylinder. There are also gears in the differential housing that are reffered to as side or spider gears.
Jun 21, 2009 | 2001 Chevrolet Blazer
Kenmore 70 series won't spin
If the washer makes a noise from the front bottom center, when not agitating and not spinning, the motor/gearbox coupling has broken.
closed2a0a669.jpg open7976f3d.jpg It is designed to break, if the load gets enough that the motor may be damaged and is simple (enough) to replace
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models but close enough, some have 2 clips some 3
  • remove screws under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips at rear corners
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Oct 26, 2008 | Kenmore 22422 Top Load Washer
Does not spin
there is a coupling between the motor and gearbox, that fails.
it is a simple repair, and well worth trying
remove cabinet
  • pop off edge trims from control console
  • remove screwss from under edge trim
  • slide console forward and up ~1inch
  • flip the console over the back of the washer, the hinges are plastic and a little fragile
  • remove brass clips holding cabint inplace remember how they fit
  • lift cabinet ~1inch and remove forward
repair coupling
  • motor gearboxpump is at front bottom center
  • remove lock screw from clip holding pump to motor
  • remove two spring clips
  • pull pump off motor and swing sideways on hoses, tie off to left with a string
  • remove lock screw from clip holding motor to gearbox
  • pull motor off rubber coupling
  • pull nylon spider off gearbox shaft
  • pull nylon spider off motor shaft
  • install new spiders to shafts. Use a hammer to strike a wooden dowel on the center of the spider, dont hit the legs of the spider they break off
    Note the new coupling spiders have metal centers to stop further breakage, common fault
  • turn gearbox spider 1 leg up two legs down
    turn motor spider , 2 leg up 1 leg down so the spiders will interlock
  • install new rubber coupling on gearbox spider, install motor on coupling.
reassemble all clips and screws in reverse order
reassemble case in reverse order
on reassemble ensure plastic level sensing hose is not dislodged from water level switch body
takes longer to type than to do the repair
at parts store "Kenmore gearbox coupling" will get the correct part
Sep 07, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 series agitator problem.
usually it is a gearbox drive coupling, designed to break on exceptional loads
  • remove trims from ends of control panel
  • remove scres under trims
pump
pump springclips
body
control panel
Jul 13, 2008 | Roper RAS8445KQ Top Load Washer
Baby Gear Logo
67 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
