Question about Sharp AR-5316 Advanced Digital Imager Copier
AR-5127 Photocopy machine - An error appeared U2-40
All action stops in copier. A U2-40 error code appears in window. Nothing seems to help or remove error code, including the C-CA-Interrupt-CA sequence. i have tried alot of time. help me.
All action bloked code: L6-10
please healp me
Posted on Jan 06, 2011
    New Friend:
My photocopier is showing call for service with error code H-04. what will i do to solve then problem. Copier model number is AR-M207
Posted on Feb 19, 2013
  • Sharp Expert
  • 316 Answers
L6 polygonmotor lock detection
Posted on Apr 12, 2011
  • 41 Answers
Try the following code - clear / interrupt / o / interrupt.
punch in 16 and press ok/enter
U2 error code will be cleared.restart your machine.
Posted on Jun 18, 2009
Mx2300n error code u2-30
Try this #, Interrupt,c,interrupt
use the ten key pad type 16 press start
ok
start
interrupt
ca
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 13, 2016 | Sharp MX-2300N Color Copier
I have the copier machine Sharp AR-5127, the error code H4-00 appears and coping cannot be done what do i do
The heating element or the thermal fuse in the fuser unit has failed. Try pressing clear,interupt, 0, interupt, 1,4, the blue copy button to reset it.
May 23, 2012 | Office Equipment & Supplies
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Hi My Sharp AR-275 has problem of U2-40 now. I tried Solution 1 or removing toner cartridge and replacing the same one (because there is still 50% left). And also I tried Solution 2 or press #...
The U2-40 error is the machine telling you that there is a communications error with your CRUM chip.
is there anything at all displayed on the screen??
if there is, press the #, interrupt, C, interrupt in rapid succession. If you don't know what the interrupt button looks like, it is the third button from the right on the control panel. You may have to try it a few times, as with age, the buttons are harder to push so they register that you are pushing them. Once you get into the simulation mode, press 16, then start, and follow the on-screen instructions. once the machine has reset the code, usually shows by going back to the main code screen, then press the CA button, or "clear all".(second button from the right) that will reboot the machine and hopefully clear the code.
Nov 03, 2010 | Sharp AR-275 Copier
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
937 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
