Question about Canon MV650i Mini DV Digital Camcorder
Cannon mv650i cassette stuck - how to remove it please? Thanks
2 Suggested Answers
cpt100
  • 154 Answers
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Posted on Mar 17, 2007
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
Need a manual for the Canon MV530i
To download the instruction manual for required product, please click the respective link below:
Canon MV530i Manual
Canon MV650i Manual (Product category selected)
Please rate the solution.... :)
Thank you
Dec 02, 2008 | Canon MV650i Mini DV Digital Camcorder
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
Nov 13, 2008 | Canon MV650i Mini DV Digital Camcorder
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Power save feature
ارغب في برنامج لتعريف كاميرا نوع كانون mv650i
Apr 21, 2008 | Canon MV650i Mini DV Digital Camcorder
Canon MV650i
First of all is it still under warrent? Did u get it at Sears? The blue screen looks like it would if u have it on play with it stoped?
Aug 15, 2007 | Canon MV650i Mini DV Digital Camcorder
Cassette will not load!
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100.
Jun 22, 2007 | Canon ZR100 Mini DV Digital Camcorder
NOT TAKING TAPE
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100. Of course mine is out of warranty. Everyone should call Cannon and complain.
Apr 09, 2007 | Canon ZR100 Mini DV Digital Camcorder
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Canon MV650i Mini DV Digital Camcorder Logo
48 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
