Question about GE Deluxe AGM08LJ Thru-Wall/Window Air Conditioner
My GE A/C window unit won't shut off or let me change the temp.
  • 3,267 Answers
Please get the thermostat replaced before your compressor breaks down due to continuous running..............sodeep
Posted on Jun 18, 2009
GE small refrigerator runs all the time.
If it is running all the time it is due to
1 - defective thermostat
2 - low refrigerant not allowing unit to reach correct temp to shut off compressor.
3 - Check that condenser motor is running and the condenser tubing is clean
Jun 15, 2017 | GE Refrigerators
Why won't my GE electric dryer shut off? My GE
The model number you submitted is not valid. Long dry times and dryer not shutting off is either an element problem, an air flow problem. Lets begin with a good model number so we can see your unit as you do...
Waiting to hear from you,Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
Apr 20, 2012 | GE Dryers
Ge monogram not cooling
You can fool with this and loose all your food to spoilage or get a service tech out to fix it or just replace it.
Jul 25, 2017 | Refrigerators
The compressor on my ge ASH10ABS1 window air conditioner starts and operates fine but won't shut off even when the temp control is lowered. What's up?
when attempt to I power up my GE window unit, a message
' E1' shows, and the unit does not start. what is it telling me ??
May 19, 2010 | Heating & Cooling
Ge Zoneline heatpump works fine in the summer but in the winter with 45 to 50 degree days the compresser hardly runs. By turning the thremostate you can get it to run for a short period. I have 6 of these...
These Ge Zonelines have and ambiant Temp control on the unit when the temp drops it drops out the compressor and goes to electric heat. This keeps the unit from getting iced up. They do go bad and sometimes they shut off to soon. I just replace them and everything goes back to normal. They are located on the outside part of the unit. Just slide out the unit and it is located I beleive on the right side of unit Rus.
Dec 17, 2009 | Humidifiers
GE AEW10AJS1 Window Unit A/C Shuts Off and Trips Reset.
The condenser coils may be dirty. You can wash them out with a hose or compressed air.
Jul 20, 2009 | GE AJCQ08ACB Air Conditioner
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
I have a GE window unit. I do not hear or see any water draining.. and I do not hear any change in the way the unit runs like I used to when it would blow really cold air. The air is cool - but not cold...
May need to wash out the out door coil. Normally spray through rear coil at about a 30 degree angle. try not to spray water directly into fan motor. If unit is freezing up it may be low on freon. if it is real hot out you may need to run 24 hour a day. High indoor humidity will affect its output also. could have weak compressor. check temp drop accross indoor coil. Shoud be 20 - 30 degrees in most cases cooler than room temp.
Jun 23, 2009 | GE AJCQ08ACB Air Conditioner
GE AGM08LJG1 window unit: digital temp increases on its own. Ex: when set to 65 degrees (and timer set to turn the unit off in 4 hours), return to the room 2 hrs later and the digital temp reads 69. What...
its telling you the room temp that is been sucked into the evaporator.its normal for this to happen.once you set the temp you want.it stays there untile you change it.but its all good.
Jun 09, 2009 | GE Deluxe AGM08LJ Thru-Wall/Window Air...
GE Deluxe AGM08LJ Thru-Wall/Window Air Conditioner Logo
216 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
