Transistor tt2206 what is the normal reading of a tt2206 transistor using analog tester?
3 Suggested Answers
  • 6 Answers
SOURCE: SAMSUNG TV.22 INCHES.THE TRANSISTOR TT2206
you can also change ah D2499 horizontal output
Posted on Jul 18, 2011
gopakumarg43
  • 75304 Answers
SOURCE: equivalence transistor tt2206
Equivalent Sanyo 2S?5793
Features : I(c) : 10A, V(cbo) : 1600V
1. High speed.
2. High breakdown voltage (Vcbo=1600V, Vceo=800V, Ic=10A, Pc=65W ).
3. High reliability (Adoption of HVP process).
4. Adoption of MBIT process.
TT2206 equivalent circuit is 2S?5793, TT2202, JL6920, 2SC5446
Posted on Dec 20, 2016
Equivalence transistor tt2206
1. High speed.
Dec 19, 2016 | Televison & Video
Need a look up chart for the transistor and diode checker
A tester for transistors uses an oscillator tank circuit to see if the transistor will oscillate. What is the make and model of the tester that you are using?
Sep 14, 2014 | Televison & Video
I change the TT2206 transistor of samsung tv model CS-29Z58M1 because it is shorted, after i replace,it works but after three minutes it shorted again and tv does not work,
Check and replace damaged components associated with horizontal output section circuit. Check the FBT too. Check this link for more details. Pull up older posts there.
Mar 18, 2013 | Televison & Video
29 onida oxigen h out complant
you mean a horizontal output transistor problem with your tv unit?. there are possible cause why a horizontal transistor get bad. it depends to what kind of trouble does the tv unit have. here are some of trouble that i encountered of H-out problem and how i fix it
  • leak regulator transistor, the problem of the tv unit when you turn on it works but suddenly shut down then the horizontal output get bad. now how are you going to know if the transistor is leak and shorted. by means of a digital multi tester or an analog tester. a good transistor must have a reading of .4 to .9 in a digital tester below or above to the range is said to be leak transistor. a regulator transistor is usually found at power supply section. how to test a transistor using the digital tester. get the tester and then pull out the transistor to chassis board. vinceisaac_24.jpg as you can see in the image above is a digital tester some other brands may vary in ranges but all the function are the same. now set the pointer to the resistance checking select to the range with diode sign. a transistor have 3 pins for base, emitter and collector (component term ) with the use of test probe now touch one end of probe either of the 3 pins and other probe to the other pin.check the reading to the display of tester if no reaction reverse the polarity until you find the correct reading as what i said a good transistor is about .4 to.9 and then try this process to the other pin of transistor to check if all the junction are good.
  • defective deflection yoke, the problem with the tv every time you turn on unit the horizontal output get damaged. a deflection yoke composed of two windings for vertical and horizontal coil ( technical term ). now how will you know if the coil has problem. a yoke has 4 wires, 2 wires for vertical and the other 2 wires for horizontal now with the use of digital tester set the pointer to the resistance checking either in a lower range. touch with the test probe either of the 2 wires check the reading if 0000 that means shorted sometimes cause by an over heat the insulation get damaged. repeat the process to the other 2 wires, a good coil at least has a reading about .5 to 1 ohm for horizontal and for vertical around 1.6 to 6 ohms it may vary depending to the yoke needed by the tv unit. vinceisaac_25.jpg the image above is sample of deflection yoke it was located and installed at the neck of ( crt )picture tube. if one of the coil winding has problem it always damaged horizontal output transistor and other part . i hope this trouble that i encountered will help you too to fix your problem good luck.
Jun 03, 2011 | Televison & Video
Philps match line flat screen tv red light flashing on the tv wont turn on
hello sir..your problem is usually happen when the circuit have shorted parts transistor or even diode...try to test by using multimeter tester range it diode testing for digital tester and for analog range it to ohms..first step is find the base of the transistor.then go for forward testing your tester should got reading after that reverse your test prove if the reverse testing got a reading it means your transistor shorted if not that is in good condition remember when you go for that testing procedure you should remove the parts to the circuit by using soldering iron and soldering pump..if my solution is helpful please don't forget to rate my answer thank you very much
Mar 06, 2011 | Televison & Video
Everytime I turn the receiver on, the fuse inside the unit will burn up and the receiver shuts off.
hello sir..your problem is usually happen when the circuit have shorted parts transistor or even diode...try to test by using multimeter tester range it diode testing for digital tester and for analog range it to ohms..first step is find the base of the transistor.then go for forward testing your tester should got reading after that reverse your test prove if the reverse testing got a reading it means your transistor shorted if not that is in good condition remember when you go for that testing procedure you should remove the parts to the circuit by using soldering iron and soldering pump..thank you
Siapa yg tau jenis tr tt2206 dan apa penggantinya
Hallo mr. Ragil, Welcome to FixYa,
Ini transistor utkTv. Ini digunakan utk tv yang horisontalnya bermasalah. Boleh di cari di toko sparepart electronik di Jakarta atau dipesan saja lewat service electronik terdekat.
Salam, di vote ya, Jaya
Jan 24, 2011 | Televison & Video
Charger problem
A phone charger is supposed not to be serviceable (you must not replace components). As this is a safety device, and even a bad solder joint can cause a serious hazard (fire, shock, phone blown).
The only way to find out the value of this transistor is by using a multimeter with diode tester function and testing the transistor as if it was a circuit of two diodes (that is what a transistor is), see here: Testing semiconductors with analog and digital multimeters. , also Transistor.
If the transistor has blown this will be impossible.
Try also going to a spare component shop with the transistor and circuit, this is what we all do when we do not have the schematics and value.
Being this a $8 charger, better buying a replacement:
Sagem my202C European Mains Charger EU 2-Pin
Sagem my202c Chargers uk 3 pin plug
Apr 15, 2009 | Sagem my301L Cellular Phone
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
