Question about USA Spec SCD-D50 6-Disc CD Changer
Usa spec 6 disk cd changer problem
I have a 6 disk cd changer USA SPEC SCD-D50 in my 2000 Daewoo Leganza. When I push the cdc button on the factory raido it ejects the cd cartrige in the trunk but does not play. If I push the eject button on the changer itself it does nothing. How can I fix this myself and what would it cost approx. to get this fixed if I cant fix it myself?
  • 3,230 Answers
Well, it seems like the control board of your CD changer need to be replaced.
it cost approx. $50.
Good Luck!!
Thanks
Posted on Jun 18, 2009
What aftermarket stereos will work with usa spec scd-f100
That unit is designed to work on Ford vehicles that have a CD button but no CD changer.
Oct 13, 2012 | Ford F-250 Cars & Trucks
The eject button does not work on my grundig rcd300 car stereo
Sorry but it have to be replaced or taken out and sent to be repaired.
Nov 06, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Need pinout for USA SPEC SCD-A88 CD changer. The unit has a short (~6in) cable with a round 8-pin connector on the end. In particular I want to apply 12V and GND so I can eject the discs that are trapped...
Sorry to hear it I had same prob with vw88e tried to email usa spec and get pin out but no results.. had to get the screwdrivers.. DO THIS ON A CLEAR TABLE WITH GOOD LIGHT !!face pops off easy enough ya gotta have 3 hands to gently hold ones youve popped and work the others then 6 little screws 3 on each side.. CAREFUL not to drop the little sliders for mounting in car they have springs that pull them out of thier home and they **** to get back in remove the top.you should be looking at the top now and can see the cartridge..and a little bit of the cd that was last playing.
there's a large gear.. with a pin in a half moon with a little flat tail lookin slot. if the pin is in the little flat area, carefully spin the gear until its out of flat and around to top of moon. cd that was playing is now in cartridge.. on the bottom in the back is another little gear (Between the mechanical case and outer shell) carefully spin that gear until the disk selector is all the way down (if it goes up or doesn't move spin the other way) keep spinning until cartridge ejects if you want reassemble if you just wanted disks toss it as is if reassembling just go reverse face plate goes on last
Oct 12, 2009 | USA Spec SCD-A88 6-Disc CD Changer
Car cd changer problem
cd changer not working in leganza
Jun 18, 2009 | USA Spec SCD-D50 6-Disc CD Changer
My 2001 Jetta 6 disc changer has a cassette but I don't know how to get it out of the changer. Does the car need to be on?
The front of the disc changer has a sliding panel (usualy the left side slides to the right). After you open it completely either on left or right bottom (inside) you will see a little red or yellow push button. This allows to eject the cassette. No, the car doesn't need to be on, but depending if the wiring is standard or not it doesn't harm if the car is on.
Jun 14, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Cd player not working
after a while of use the cd laser reader gets misalign and the radio go out just pick up a new radio and put it in
May 16, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Sony cd changer
IF IT'S A FIAT BRAVA ORIGINAL CAR RADIO WITH A SONY CHANGER IT WILL HAVE AN INTERFACE BEHIND THE RADIO WHICH MAY NEED RESETTING IF YOU DISCONNECT THE INTERFACE POWER FOR 2 MINS AND RECONNECT IT FAILING THAT THE SONY 6 DISC WILL BE JAMMED, WHICH IS COMMON
Nov 19, 2007 | USA Spec SCD-A88 6-Disc CD Changer
USA SPEC MERC99
Unplug all the cables, leave it out for several hours then replug it in and eject. This happen to me, I called 1-800 Mercedes and that's what they told me and it worked.
Sep 27, 2006 | USA Spec MERC99 6-Disc CD Changer
USA Spec SCD-D50 6-Disc CD Changer Logo
50 people viewed this question
Top USA Spec Car Audio & Video Experts
xxxxxx xxx
Are you an USA Spec Car Audio and Video Expert? Answer questions, earn points and help others
