Question about Kenmore Washing Machines
Tub not spinning and smells like its hot, could it be the belt
  • 957 Answers
Yes it could be the belt if it is slipping it will smell with a little bit rubber burning. u can check the pulley on the motor to make sure it is not loose.
Posted on Apr 17, 2014
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Tub not spinning
tub will not spin, smells like it is burning
Aug 16, 2012 | Speed Queen AWN412 Top Load Washer
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Model number WDSR2080G3WW. GE Top Loading Washing machine will not spin. It fills, agitates and drains but does not spin. Lid switch engages, motor tries to start the spin it won't spin, so the motor...
The reason for the hot smell must be investigated. If it is the motor that is getting hot it won't be a new motor for very long. The hot smell might be coming from a drive belt or a clutch and there could be a brake mechanism that is binding or not fully releasing.
Clearly the next step is to closely observe the operation of the mechanical parts...
Sep 15, 2017 | Washing Machines
When washer is spinning it smells like something is burning
A burning smell means you have some slipping of the drive belt. I think your belt needs to be replaced. Another reason may be a binding in the tub. possibly a seized tub bearing. The only way to know is to take off the access cover at the back of the washer and visually inspect it first. you can spin the tub by hand from the back and this will give you an idea of what is binding.
May 26, 2010 | Kenmore 24032\24036 Top Load Washer
Washer does not spin, has a burning smell. took off front panel. motor pulley feels hot, so does belt. replaced belt 6/09. only wash one load per week. where is the burning smell coming from?
This sounds like a frigidaire washer. If it is, the belt must be the original equipment manufacturers belt. ANY other belt will just slip and burn. The fact that the pulley and the belt were both hot tells me that either the belt is the issue or your main tub bearing is starting to seize.
Mar 18, 2010 | Washing Machines
The washer will go into final spin, it seems to be
Well there could be few things causing the smell and the tub not turning. Its possible something is restricting the tub from turning and the motor is over heating. It is also possible that the transmission has a broken gear and you are smelling something from it getting hot inside. Or you could have a bad belt or coupling. Also the water pump could be stopped up. Its hard to tell because there are so many different types of washers and Im not sure which one you have I assume it is a whirlpool late model.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin on spin cycle, smells of something burning.
sounds like the belt or the tub bearings are shot. It is likely that the motor is spinning and the tub is not, causing the belt to burn.
May 25, 2009 | Maytag Washing Machines
Washing Machines Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
