Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire front load washe makes an awful noise when water starts to drain
The washer works and sounds normal on the onset, but a horrible noise comes from the pump (?) when draining the water. Where is the pump located on this washer?
  • 26 Answers
Yes normally remove the bottom panel and the pump is in the front on the right side. Some companies recommend you clean it every few months. Also some will let out water when you open it up, so have a towel ready.
Posted on Apr 14, 2014
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Posted on Jul 09, 2009
milten1
  • 1304 Answers
SOURCE: I have a LTF2940ES1 horrible noise and wet clothes
you ahve a clogged pump
remove the toe kick
the pump will be right there on the right
get a towel and disconnect the hoses
you will see a sqaure sump take that hose off
and clean it out
check to make sure there is nothing in the pump
reassemble and should be fine
Posted on Oct 07, 2009
  • 1531 Answers
SOURCE: my frigidaire GLTF2940ES washes but doesnt spin on
replace the door lock mechanism
Posted on Apr 10, 2010
Macmarkus
  • 2605 Answers
SOURCE: Frigidaire affinity front load. Starts
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Dec 12, 2010
Washer is making a horrible sound while draining water from tub
if horrible sound is while drainpump is draining but before washer starts to spin either obstruction in drain pump or impellar on pump is bad and the complete pump needs replaced... if noise is while spinning the spider support is cracked which is very exstensive repair and dont reccomend repairing unless you have a couple of hours for dissasembley and reassembley...
Jan 24, 2011 | Samsung WF337AA Front Load Washer
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
remove the toe kick
and clean it out
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
