Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
No suction Hoover Steamvac Spinscrub F5915905
SOURCE: Hoover SpinScrub
I would almost guarantee the recovery tank is not seated properly. Trust me, I reseated the tank 5-10 times before giving up. I finally decided to give it one more try before forking out the money for another cleaner. I removed the clean water tank, turned the machine on (you could feel the air blowing out the sides on the bottom). With the machine still running, I unclipped the recovery tank and lifted it up (yes, you can do this, and it creates a very loud air thrust, but don't be scared), then I SLAMMED it back down into the seat and immediately I could tell the difference. The air stopped blowing from underneath and I could tell I had suction once again. I turned it off, put the clean water tank back on, and it worked like a charm. Trust me, you may be convinced that the recovery tank is seated properly.....LOL.....it ain't! Hope this helps!
Posted on May 12, 2009
  • 19 Answers
SOURCE: Where do you connect the vacuum suction part of
Hello, please follow the link below and look in section 3-8
Please let me know if this helped you
bsix@hotmail.com
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Posted on Sep 14, 2009
  • 190 Answers
SOURCE: I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Posted on Oct 05, 2009
  • 190 Answers
SOURCE: SteamVac F5914-900 SpinScrub won't stay upright or collect water
(1) Upright: Sounds like the tab on the lower handle that the handel release latches to has broken off. The machine is fully functional without it otherwise.
(2) Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Posted on Oct 07, 2009
  • 144 Answers
SOURCE: why does my steamvac not suction the water up?
Typically there is a little red filter accessible from the bottom of the cleaner. Lay it down and flip it over to take a look. It's a little screen like filter. Large particles than can possibly cause a clog are filtered out there. Just pull it out (it will only come out part way) and clean the debris from it.
I have a Hoover Steam Vac also. Learned that trick the hard way. If that's not the problem (it usually is) then I will need the model number from your machine. Hopefully they didn't put it on the bottom of the machine where the numbers wear off. That's where mine was.
Zashiban
Posted on Jun 25, 2010
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The suction stopped working after emptying dirty water and filling up with new water and cleaner
I have an older Hoover SteamVac Supreme #F5815 and I'm having trouble figuring out how to clean the part in the front that the dirty water goes thru before it gets to the tank. How do I clean it?
Mar 06, 2011 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac shut off without making any noise
its very possible but just in case make sure the sensor is clean where you see it spinning that way you know the brushes are working open the plastic door and clean the net also if your dirt tank is full the suction will slow i am not sure if it will just stop but check that anyway too
GOODLUCK Godbless
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction in new Hoover Steam Vacs
http://www.hoover.com/pdfs/manuals/F5914900.pdf hopefully this helps
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SpinScrub Carpet Cleaner
I was having the same problem, the black seal under the tank that captures the water was broken, and it wasn't getting any suction.
Nov 05, 2007 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
