Question about Garden
How to change the fule line of weed eater?
I can't start this weed eater.
  • 24 Answers
There should be clamps on either end of the fuel line..1.. empty the fuel out of the weed wacker ..2..loosen the clamps..3..remove the hose ..make sure you are careful when replacing any fuel lines..so you dont puncture a brand new one..tighten the clamps good but not too hard or you can pucturethe hose that way too and make sure its the right one for that model. make sure the line is also fuel resistant..gasoline can eat through the wrong type of line. You should be able to buy the fuel line and clamps at any hardware store:)remember to ask for help from someone in the right department
Posted on Apr 14, 2014
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Ryobi weed eater troubleshooting
    Here is a video I found helpful.
    https://www.youtube.com/watch?v=iMFUW6DJia0
    Aug 19, 2014 | Garden
    Weed Eater GTI 19T
    If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
    Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
    Why won't my McColluch weed eater create a vacuum
    Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
    May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
    Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
    change the fuel lines over on the carby
    you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
    Mar 12, 2017 | Garden
    How do I remove the spoolhead so as to afix the pivotrim head
    I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
    Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
    Enjoy! :-D
    Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
    Weed eater wont start
    If you haven't changed fuel filter in awhile, do that as well.
    look here...
    Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
    Powerpro 17" McCollich weed eater
    hey harry the float inside the carb is stuck i would suggest rebuilding the carb
    Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Ryobi petrol weed eater
    SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
    Dec 08, 2009 | Ryobi Garden
    ECHO 2000 WEED EATER I changed the fuel line,
    You may need the carburetor adjusted or rebuilt. The other possible item is "bad gas". If the gas has been sitting around longer than 30 days, it may be time to mix up some fresh fuel mixture.
    HTH
    Good Day.
    Oct 29, 2009 | Garden
    Garden Logo
    90 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
