LG MONITOR 700E SCREEN PROBLEM
ONLY HALF SCREEN ON SLAPPIN ON SIDES SCREEN COMES FULL PL HELP
  • 16 Answers
SOURCE: for lg monitor warranty
this monitor having 3 yr warranty
according to the serial no it have warranty till April 2008.
Posted on Feb 06, 2008
ginko
  • 19396 Answers
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
  • 10 Answers
SOURCE: 700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Posted on Aug 25, 2009
SOURCE: How to adjust lg 700e monitor screen shape, size
desktop size told me
Posted on Apr 18, 2010
  • 10 Answers
SOURCE: LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Posted on Dec 10, 2010
LG 700e crt monitor is showing all in rainbows!!!!
Remove any speakers or magnets that you might have near the monitor as they can cause visual distortion on your monitor screen.
Mar 05, 2014 | LG Studioworks 700S 17" CRT Monitor
Lg 700e monitor settings
the correct settings for LG 700E CRT Monitor. Sometimes, the settings ofthe monitor change automatically. Also, even after resetting the monitorsettings, sometimes, they remain same. So, I'll tell you the correct settingsfor LG 700E CRT monitor. Let's move to the main part.
So, Check the following settings.
ForBrightness and Contrast:
http://is.gd/dMBn9
For Position:
http://is.gd/dMBub
For Size:
http://is.gd/dMBBU
For Shape:
http://is.gd/dMBDC
http://is.gd/dMBGe
Oct 20, 2012 | Computers & Internet
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
LG 700E monitor's power LED blinking continueously, no displaySolution.............
Jan 23, 2009 | LG Studioworks 700S 17" CRT Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
LG STUDIOWORKS 500g - FULL SCREEN NOT GETTING DISPLAYED
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
Aug 31, 2008 | LG Studioworks 45 14" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
