Question about Kenwood KAC-729S Car Audio Amplifier
How to install kenwood 729s withno rca outlet on radio
What's the best way to hook up a kenwood 729s with no rca outlet on radio/cd player? Right On!
    Scholar:
    New Friend:
  • 82 Answers
You can run the speaker wires to the speaker level input on the amp or i believe you can run another set of speaker wires spliced into the existing wires in parallel to the speaker level input along with the speakers that are already hooked up if you are using the amp for a sub or other speakers that you have added to the existing system.
Posted on Apr 20, 2014
2 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Kenwood KAC-729S keeps blowing fuses.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Posted on Sep 20, 2009
Sirius Sound only on front right speaker !!
is your satellite an external device? and if so what kind of adaptor or harness does it use to hook up with main radio?
Dec 27, 2007 | Kenwood DNX7100 Car Video Player
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
I have a kenwood ddx318 2 dinn radio and want to hook it up to my overhead DVD player so we can all watch the same movie ! Do I need RCA line ?
Hello! The unit has an "AUX" input that uses typical White, Red and Yellow RCA cables...Red is right...White is left and Yellow is video...Guru...saailer
Jan 20, 2012 | Kenwood Car Audio & Video
Does radio or CD player have RCA plugs?
not usually on stock stereos but lots of aftermarket stereos have rca attachments. If you want my advice go to crutchfield.com and order from them. they will sent you the stereo you want plus all the gear to install it the right way.
Nov 10, 2011 | Cars & Trucks
Can i hook up my cd player which is a kenwood cd-323m to a vr507 kenwood receiver
hi,
Yes you will be able to connect the same. Connect the line output of the KENWOOD CD 323M to the CD input of the KENWOOD VR507 receiver using a stereo RCA cable. The picture of the cable is added.
ok
Sep 12, 2011 | Kenwood VR-507 Receiver
My 93 Boneville CD Player does not work, the radio works fine but it will not play CD's, also how would i install a set of speakers (subwoofers)
the cd player is bad and you can hook up subs through a rca hook up that you can hook to your speaker wires in the trunk the adapter is like 20 bucks at radio shack or local sound installer or buy an after market cd player cause yours will never work again and run rca's off the back of the radio to your trunk
Jul 09, 2009 | 1993 Pontiac Bonneville
Kenwood ddx6019
the double din kit was restricting it from opening properly, once i removed it from the kit it worked properly. i had to modify the kit for it to work properly!
May 25, 2008 | Kenwood DDX-6019 Car DVD Player
My kenwood kdc-mp235
I assume the amp is turning on (lighting up) No audio may be due to Burnt rca ground trace in your kenwood radio. If you have a ohm meter measure continuity from rca's ground terminal to radio chassis. Should be close to zero resistance. If there is no no continuity there are fusible traces on radios main board that burn open at times when to much current is flowing thru rca ground
Just a good possibility , haver seen this happedmany times.
If you need service manual let me know kstahl65@att.net
Jan 23, 2008 | Car Audio & Video
Amp not working
1. Did you witness this amp ever working if not then you may have a blown amp. Hook up the speakers, get a portable player with a head phone jack get one of those cables with a headphone plug on one end and RCA's on the other plug the portable player into the amp and hit play. If sound comes out then your problems are elsewhere. If not I'm afraid your amp is probably toast. If the OHM rating of the speakers are too low for the amp then the amp will go into protect. This will be indicated by the protect LED lighting up or the power led changing color from say green to red.
Jun 28, 2007 | Kenwood KAC-729S Car Audio Amplifier
Kenwood KAC-729S Car Audio Amplifier Logo
103 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
