Question about Pit SSR 110CC Pro Beginner Bike
Starting got compression just did gaskets new plug set specs got spark new gas cleaned carb
    Sergeant:
    Champion:
  • 285 Answers
Are you getting fuel and spark?
Posted on Apr 14, 2014
How do I check the timing after I put a new head gasket on, and now it will not start, I have got fire on the spark plug, I took the carb off and cleaned it, Still will not start
take the nut and cover off of the fly wheel. you should see the fly wheel key if it is sheared then it need to be replaced. if it is still aligned correctly it is good. you need fuel spark and compression to run. spray some carb cleaner in the carb. if it starts for a second something is wrong in the fuel area. you should see spark on the plug and block. check compression to be sure you have at least 40 lbs. if not the valves are probably not set correctly. assuming you got the head gasket on right.
Jun 20, 2017 | HP Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
Won't start has not been started in five years, has new gas,new oil and new spark plug
The carburator may be empty. Open it and fill it with fuel before starting.
Other way is to get a starter spray, open the input collector or where it is possible and spray while starting.
May 31, 2010 | Coleman Powermate Powermate 5000W...
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
Craftsman gas blower no start
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Will not start. few months old. maybe bad gas
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 15, 2009 | Homelite Consumer Products Backpack...
Hard to Start Bike
Hello.
Sparkplugs. That will fix it.
You can choose between 3 types the normal the cold and the hot (performance) sparkplugs. The normal for medium temperatures is the best, the cold is suited for bellow 5º C temps. And the hot is for hot weather and performance usage.
Hope that helps.
Feb 20, 2009 | 1993 Honda CBR 1000 F
Karcher 3000 psi won't start.
It sounds more like a carb problem flooding and dumping some gas into the oil. This unit probably has a low oil sensor and the gas could be affecting this. I would have somebody look at the carb and find out why doing this, change the oil and try again. I have one that leaks gas because of float problems, that has done it since new, waiting for spring to remedy. Good luck, Also you can go to Karcher.com for a parts explosion and manual if needed.
Jan 17, 2009 | Karcher G3025OH Pressure Washer
Pit SSR 110CC Pro Beginner  Bike Logo
78 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
