Question about Bowflex TC3000 Treadclimber
How to recalibrate tc3000 - Bowflex TC3000 Treadclimber
I purchased a replacement power cord for my Bowflex TC3000. I plugged in the new cord and it is not working. Is there a known incompatibility with after market power cords for this machine?
If you have access to an ohm meter then you can verify if the plug is good or bad and you can use a volt meter to verify that the outlet is working or not. The first video shows a generic way to ohm out an extension cord. this will also work with yours. The second shows you how to check voltage at an outlet.
Jul 06, 2016 | Bowflex TC3000 Treadclimber
Why would my bowflex tc3000 not calibrate?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 14, 2016 | Bowflex Nice Tc3000 Treadclimber Bow Flex...
My Bowflex Treadclimber keeps coming up with an Error L5. This error message shows up 5 seconds after turning the machine on. My husband looked it up yesterday and said that the machine needs to be...
L5 due to the screen is actually LS (lost signal) the first place to check is the gap of the speed sensor. under left treadle 2 black wires. Removing the rear covers will allow you to see the lwr cntrl board and move the belt by hand. The gren led light should flash once per revolution of the drive pulley. If not then it is the speed sensor. Adjust sensor to pully about thickness of a credit card. then calibrate unit.
LS is also tripped by any broken wires or bad connections. Start at sensor and board first.
Jul 21, 2009 | Bowflex TC3000 Treadclimber
I have a bowflex tredclimer tc1000 won't turn on.
I have a TC3000 and when it wouldn't turn on I recalibrated it using the directions from the owners manual. It's now working. Give it a try.
Jul 08, 2009 | Bowflex Treadclimber
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Error code E5-5
I didn't use mine for several years then just started again. It stopped after 15 minutes so I read the manual and used a silcone lubricant on/under the treads as recommended. That definitely helped and it was working again quite well for about a week or two. Now I get the error 5 again. Wondering if I needed to add MORE lubricant the first time so I am going to do it again tonight. Maybe it is the roller pully that needs the lubricant. Who knows. I just want it to work!! I am determined. :)
-becky
Feb 08, 2009 | Bowflex TC3000 Treadclimber
Calibration Failed
make sure speed sensor isnt to far away from left wheel or did not get unplugged from circut board
Dec 25, 2008 | Bowflex TC3000 Treadclimber
Bowflex TC3000 Treadclimber Logo
57 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Bill Boyd
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
