Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Compatible fuser unit bizhub c350 - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
4 Suggested Answers
smt24
  • 54 Answers
SOURCE: put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
Posted on Jun 03, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
SOURCE: How do you clear error code on a bizhub C350. A
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Posted on Jul 22, 2011
Bizhub C350
Fan located above the fuser unit the hot part is burned out or very dirty and can not turn
Jan 29, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
How to fix C-0500 error for BIZHUB C350 konica minolta printer
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 31, 2012 | Minolta Office Equipment & Supplies
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c350 :the flowing unit need to be replacd soon . fusing unit
Fuser units need to be replaced by a copier technician unless you are quite good at taking things apart.
Apr 23, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
C350 malfunction code c-0501
Oct 02, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Put in newer fuser unit but machine still says to replace
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Shadow printing with Blue color. C350
sounds like you may be getting ghosting from the fuser unit upper heat roller may be worn
Dec 03, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 25, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
