Question about Acer Aspire Ax1420-Ur10p Desktop PC
I have an acer aspire 1420-ur10p desk top and it wont power up, no beep light nothing, what do i do...
Turned off will not come back on
    Master:
  • 568 Answers
Check if power cord is working properly.
Check if power supply is working properly.
check if mothernboard is getting proper supply from power supply.
you can also get the cmos battery checked up
Posted on Jun 02, 2014
  • 233 Answers
SOURCE: ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
  • 166 Answers
SOURCE: we have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Posted on Aug 23, 2009
  • 124 Answers
SOURCE: desk top acer aspire T180-197z will not conect to
well done - glad it's sorted
Posted on Sep 18, 2009
  • 5 Answers
SOURCE: acer aspire m3201 wont boot up
There are numerous issues that could cause this but if absolutely nothing happens, no lights, no fans, nothing then check the power supply. Use a simple voltage tester to see if you have any voltage on the connectors going to the hard drive and cd/dvd drives. If not this is a pretty easy and relatively inexpensive fix. You can e-mail me at globalmac@yahoo.com for more help.
Posted on Jan 02, 2010
Won't shut down or boot acer aspire all in one desktop AZ1620
VIRUS. a big bad one. Try the restore discs or a bootable USB. you made a bootable restore right? RIGHT?
Mar 22, 2014 | Acer America Acer Aspire AZ1620-UR10P...
Acer, aspire beeps
try taking out the memory sticks and putting them back in one at a time (if you have more than one)
Feb 17, 2013 | Acer Computers & Internet
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
My desk top pc wont boot up im getting the first screen and the bleeps but then nothing what can i do
If you are receiving continuous beeps, it means that computer is not recognising the RAM (memory). In this you have to open the Tower and follow the below steps:
1. Turn OFF the computer
2. Open the flap of the Tower (Remove the screws from the back of Tower)
3. Now, On the Motherboard you will be able to see the RAM see the picture nanjia.jpeg
4. There should be two pins to unlock and remove it
5. Once removed, clean the terminal and replug it.
6. Turn ON the computer, it should take care of the issue
Thanks and regards,
Nov 22, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Computer wont start acer aspire L-100
CPU overheated? When you cool it down it will start. You can check whether there are lots of dust on the CPU fan and the chase of the machine, they might block the air flow and overheat the CPU.
Jul 08, 2010 | Acer Aspire L100 PC Desktop
ACER desk top computer does not start When I press the start button the light comes on the computer whirs for about 1 sec and then turns of. or nothing hapens. desktop ACE aspire ASX3200 8550 B1
There could be tons of reason for a computer not starting up! the first thing I would replace would be the power supply, then the memory sticks or even the entire motherboard could cause it. does the computer beep any tones when you first hit the power supply, no? replace the power supply unitassy.techman
May 08, 2010 | Computers & Internet
I have an Acer T180 desk top which was working OK. Now just beeps
The beeps you refer to are known as "computer2.gif beep codes" and may also be known as "computer post codes2.gif" although they are in fact slightly different with the post code being the more technically descriptive of the two.
These are very descriptive and can tell you exactly where to home in on the problem.
In the back of your manual should be a list of these beeps and if you listen very carefully the are quite similar to morse code. Its this distinction the gives you the information. If its not there then you should go here
http://www.postcodemaster.com
scroll down to the beep codes.
Oct 18, 2009 | Acer Computers & Internet
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Power supply fo acer Aspire SA 60 desk top
To my knowledge, there is no limit to the maximum wattage that can be installed in your PC. The only limitations would be:
  • the physical dimension and mounting holes;
  • the connectors and wire/pin arrangements;
  • it should not be lower than what you currently have.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 3000 Power Issues
In this case myself assume that your acer do a problem in the memory, try remove and clean the memory.
1. boot your acer without the memory. hear beep? if yes,
Only memory has a problem, if no, then;
examine the mainboard of your acer.
If you can hear a beep then fix back the memory and start the system.
if this not solve the problem, replace the memory.
In case that it hard for you to open the laptop let the repairman do it for you so that all your problem will be examine.
Jan 22, 2008 | Acer Aspire 3000 Notebook
Acer Aspire Ax1420-Ur10p Desktop PC Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
