Question about RCA F36685 36" TV
RCA p49622 will not power on at all
I went to turn it on and there was nothing. Tried cleaning it out a bit but to no aveil. Serial #01551681. Made in January 2000. Big box tv, kinda old.
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The question will be, is the part still available? Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $150 minimum to fix this particular set. Also keep in mind that most TVs that old have a very limited number of replacement parts still available. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
Hey, I got a rf power 750s. I have a jvc kd-hdr20 h.u., and a kicker 07cvr154 sub. Install went smooth, but when I turned my car on I got power in @ the amp and a lil red light at rf badge, but nothing...
Check the RCA plugs where they mount to the board and make sure the shield ground pins are not broken. If in tact a regulator might have failed not allowing power to the op-amps.
Apr 20, 2017 | Rockford Fosgate Power 750S Car Audio...
No power?
i just picked up this same unit model and 1 thing is your backwards on the LED on/off...its blue when its off, and LED goes off when turned on.
Hopefully this will help determine if its off or on
RandyMan
**Life isn't about waiting for the storm to pass...its learing to dance in the rain!!
Jun 08, 2010 | RCA Audio Players & Recorders
R56WH76 Failed Convergence Fix
OK on same circuit board as fuse up on the front part of board look at capacitor cp150 if it is swollen or puffed up it is bad 2200uf 16v use 25v and replace 2 other capacitors in same area cp114 cp120 220uf 35v.
Sep 24, 2009 | RCA R56WH76 Projection Television
My car was a bit sluggish to start then 1 day wouldn't start nothing there at all tried it tem min later and it started and has been fine til the other day went sluggish to start drove to a few places then...
check/clean battery terminals, if ok check starter wires for voltage(while turning key to start) and tightening or corrosion. If all check out ok replace the starter. If you have no voltage at the starter check your relays and ignition switch. Hopefully this helps
Aug 19, 2009 | 1998 Nissan Maxima
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
Jan 06, 2009 | RCA TH1101 MP3 Player
RCA 32v434t
Has anyone confirmed what the problem is? Mine wont turn on. The red light next to the power button just stays lit when pressed.
Oct 22, 2007 | RCA 32V420T 32" TV
TV turned off, blinking power
probably horizontal output went out,and cap(big Blue box cap).
Sep 09, 2007 | RCA F20TF20 20" TV
RCA F36685 36" TV Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
