Question about Schlage Measuring Tools & Sensors
I have a weiser deadbolt on my garage door. the door is locked.i place the key into lock and it turns freely to left and to right but i cannot disengage bolt so the door opens. there is no other way into the garage. Is there something i can do other than calling a lock smith.
  • 53 Answers
Try pulling and pushing on the door a lot as you turn the key, there may be stress on the door and deadbolt causing it to not quite unlock all the way.
Posted on Apr 14, 2014
  • 3 Answers
SOURCE: Schlage deadbolt simply failed to unlock, with key
you can buy some "grafite" powder at lowes that is made for stiff locks, it will grease it up. if that doesnt do it the your problem may be in the plunger. might it be out of line? if so straighten it and make sure the it aligns with the strike plate on the door jamb. one of those are sure to fix it.
Posted on May 14, 2009
  • 384 Answers
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Posted on Jun 24, 2009
tbirdfan1
  • 3051 Answers
SOURCE: deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Posted on Jul 22, 2009
  • 60 Answers
SOURCE: tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Posted on Oct 18, 2009
  • 2841 Answers
SOURCE: Deadbolt wont unlock
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Posted on Jan 10, 2010
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Aug 18, 2012 | Weiser Lock ED1460X3VKD Powerbolt 1000...
We locked our deadbolt lock this morning. When we returned home, we entered the key in the hole, but it was unable to turn, and we were locked outside. Why did this happen? How do we get the key to turn...
I don't have a direct answer, but I can steer you to the Customer Service web page for Weiser locks:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
There you will find the toll-free number for their Customer Service (Call Us
Toll Free: 800-677-LOCK (Mon-Sat, 7:30am - 4:00pm PST)
as well as FAX and mailing information. Good luck!
Mar 07, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Bolt doesn't open all the way
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Dec 13, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
We rekeyed our deadbolt and for some reason the key does not work and we can't unlock the door (from outside)..help!
The lock tang (the item between the two lock parts inside the door) has been turn 180 degree out of position. Take the lock off, turn tang 180 degrees, reassamble, and it should work like new.
Sep 01, 2009 | Weiser Lock Locks & Locksmithing
Measuring Tools & Sensors Logo
76 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
