Question about OEM 2002 Infiniti I35 Radio / CD Player 3tl801610 receiver, AM-FM-stereo-cassette models w/Nav sys San Francisco, California
02 infinity i35 car no start engine turns over no spark and dont hear fuel pump
Ran when parked
  • William Bumphus Apr 14, 2014
    this is an engine problem not radio problem
2003 i35 infinity will not go past 2200 rpm
Might change the fuel filter. It might not be allowing enough fuel to the engine.
Aug 08, 2016 | 2003 Infiniti I35
02 infiniti i35 engine turn over wont start no spark or fuel
if its cranking the problem may be the crank ecu fuse or crank sensor
Apr 14, 2014 | 2004 Infiniti Q45
Shut the explorer to put in gas tried to start it, it turns over but will not start
engine could have flooded could have leaking fuel injectors or clogged air filter.hold accelerator to floor to clear flood mode see if engine try to crank if not listen for fuel pump operation when you turn on ignition switch fuel pump should turn on for few seconds.if you dont hear fuel pump could have bad fuel pump fuse or relay.now if you ran out of fuel just getting to gas station could have damaged fuel pump.if getting fuel check for spark.could have faulty crankshaft position sensor or camshaft sensor.but have vechicle code scan first before buying new parts.
Dec 25, 2012 | Cars & Trucks
02 Infiniti I35 Idling high, help!
The cause of this is either a defective idle speed control valve or an intake maniflod gasket leak. The Catalytic Converter has nothing to do with idle, so that was not money well spent.
May 25, 2012 | Infiniti I35 Cars & Trucks
My 91 infiniti q45 ran out of gas. I put fuel in and it still won't start.
you have to turn the switch on and off, but dont crank, you will hear the fuel pump come on then go off, keep doing this for a few minutes and it should start
Feb 03, 2010 | 1997 Infiniti.5 Q45
93 buick Park ave ultra wont start. Turns over fine, but wont start. Was sitting awhile, 2 months. Ran o/k before that.
make sure there is gas in tank. turn ignition switch to the on position.listen for fuel pump.if yes check for spark at plugs.if no you dont hear fuel pump.check fuse and relay.if both dont work.scan it to check for faulty crankshaft sensor fuel pump and pcm.
Jul 18, 2009 | 1996 Buick Park Avenue
Turns over and wont start
it needs a new sparke pluge
May 25, 2009 | 2000 Mitsubishi Galant
How to check if there is spark on 94 jeep cherokee
U pull a spark plug wire off, then stick a plastic handle screwdriver into the end of the plug wire and hold it next to metal of the engine, have someone crank the engine over and you will hear and see a spark
Mar 24, 2009 | 1994 Jeep Cherokee Country
2000 dodge 1500 truck will not start
spark plugs, fuel filter, fuel pump, battery, starter,?
Jan 16, 2009 | 1987 Dodge Pickup 2WD
OEM 2002 Infiniti I35 Radio / CD Player 3tl801610 receiver, AM-FM-stereo-cassette models w/Nav sys San Francisco, California Logo
Top OEM Audio Players & Recorders Experts
Robert Rankin
 Mikey
Mikey
Are you an OEM Audio Player and Recorder Expert? Answer questions, earn points and help others
