Question about Toshiba Satellite P755-s5120 Core I7 Pc Laptop
Can't use keyboard
Keyboard isn't responsive, Can't get past error message screen. Windows won't start up. Can I connect a wired keyboard and have it working before turning on the computer?
3 Suggested Answers
  • 3 Answers
SOURCE: Error screen
you can try unpluging it and take the battery out push the on button 2 time wait for 2 min. in then pluge it in and put the battery back
Posted on Jan 08, 2008
  • 733 Answers
SOURCE: can't unlock keyboard
hello,
try the following:
press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it
Posted on Oct 12, 2012
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
On my Toshiba Satellite Laptop I have opened and started the computer but can't get past the sign in window because my enter key and space bar won't respond. I can type letters but can not enter...
> hardware problem or software or keyboard?
Experiment #1: turn the computer off. Connect a USB keyboard. Turn the computer on. Use that keyboard to try the 'TAB' key (to move from field-to-field). If TAB works, then try using the SPACE or ENTER keys.
Experiment #2: turn the computer off. Turn the computer on, and look for the message:
PRESS <blah> to ENTER BIOS SETUP
When you see the message, press the <blah> key. On the BIOS SETUP menus, try the ENTER key to "select" a field, to prove that the ENTER key works fine.
Experiment #3: Turn the computer off. Disconnect the AC power. Remove the battery.
Remove the disk-drive. Take the original CD/DVD disk, and start to install Windows to the disk-drive. As you work through the installation screens, you'll need to press ENTER at least once,
if only to acknowledge that installation cannot proceed, because the disk-drive is not connected.
If the ENTER key works, it works.
Experiment #4: Like #3, but connect a different, empty, disk-drive, and reinstall Windows.
If it completes, then your "original" setup has a SOFTWARE problem.
Jul 14, 2011 | Computers & Internet
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
Window Vista problem??
If you receive this error message or encounter difficulties when attempting to launch Pro Tools using Windows Vista disabling DEP may solve the problem.
This option disables "Data Execution Prevention", a feature of Windows that can sometimes cause errors. This won’t harm anything, but also isn’t always necessary.
How to Disable DEP:
1. Click "Start"
2. Click "All Programs"
3. Click "Accessories"
4. Right Click on "Command Prompt"
5. Left click on "Run as Administrator"
6. Click the Allow button if it asks you for permission
7. Type or copy and paste this into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOff
8. Hit enter and you should see the confirmation: Operation Completed Successfully
9. Reboot and DEP should be off.
If you would like to re-enable DEP enter the following into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOn
Hit enter and you should see the confirmation: Operation Completed Successfully. After restarting the computer, DEP will be re-enabled.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
I put the USB plug in the two plug housings and the control immage on the screen still says "plug it in". It looks to me that my PC does not recognize my logitech web cam as it did in the past.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 03, 2009 | Logitech EasyCall Desktop Retail Keyboard,...
Toshiba Satellite P755-s5120 Core I7 Pc Laptop Logo
11 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
