Question about Acer Computers & Internet
My computer will not power up when i push the power button its an acer aspire desk top
Its a desk top
  • etrc_new Jun 02, 2014
    Hi jimmy kline, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Benimur
  • 6966 Answers
SOURCE: Acer Desk top help please
There are two (2) default/factory settings in your Desktop PC:
1. Motherboard (hardware) - you need to open the casing and set the jumpers to reset or alternately, you can simply remove the Lithium battery for a couple of minutes and the motherboard CMOS/BIOS will restore to default fail safe settings. You will notice that even the date/time will revert back.
2. OS (software) - If you are running a version of Windows, there normally is a System Restore feature where the OS will revert to the first time it was installed. Better yet, you can run the recovery/restore CD that came with the PC when it was new. Pop it in your CD tray, set the PC to boot first from your CD ROM and follow on-screen instructions.
Of course doing any of the above will restore the PC to its original settings but that would mean that most if not all of your added applications, saved files, settings and configurations would be either gone or no longer would be working.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 10, 2008
jonniewalker
  • 1029 Answers
SOURCE: MY ACER ASPIRE 1640 LAP
check the power supply to the mains where the lap top is plugged and comfirm if there is power supply and for any possible drop in power output which may affect the charging
Posted on Aug 04, 2008
pinoy_atinto
  • 52 Answers
SOURCE: acer aspire T120c wont start red
If you turn on the computer and it will beep once and the red light blinks means the computer is starting will.. but if the computer beep once and the red light blinks once means there are something missing or something bothering the computer.. try this Check the connection cable of your computer, the power source, the hardware interface, and if you installed a new hardware, try taking that hardware out and turn on again the computer. if the problem still exist try to disassemble and assemble the hardware of the computer. You must have someone with you know how to assemble and disassemble the computer hardware for safety method TY.
HOPE I CAN HELP
Posted on Dec 05, 2008
gurutim
  • 68 Answers
SOURCE: dell dimension 3000 desk top, does not turn on ?
It's one of two problems: bad power supply, or bad motherboard. If you are electro-mech inclined, remove the power supply. Take it to your local computer repair shop, and ask for one just like that one.
Reinstall, power up should (most of the time) fix this problem. If still no power, you need a new mb. Return to the shop, ask them to replace mb. This repair should be right around $250.0 - tops. Any more than that - replace computer.
Hope this helps. Either way, if you wouldn't mind taking the time to rate my response, it would be much appreciated!
Thanx and good luck.
gurutim
Posted on Mar 22, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: i have an acer aspire desk top computer can i put
The mini Acer uses a "small form factor" (SFF) and doesn't have room inside the case for standard expansion cards. These systems were not intended to be opened and worked on. You can still use a USB wireless adapter, though. Simply plug the adapter into an available USB connection on the rear panel, follow the adapter manufacturer's installation instructions, and you will have wireless capability.
Posted on Apr 06, 2009
First make sure that computer is getting power, check that AC cable is connected and led light is on behind the computer. Remove the cable for a while, then but it back in. Push down the power button for 10 seconds. Then try to start the computer.
Apr 14, 2014 | Acer Computers & Internet
My aspire ast180-ea 350b won't power on
This sounds as though the power supply unit within the desktop has failed.
You should be able to buy a standard replacement from your local computer repair shop.
Dec 10, 2013 | Acer Aspire Computers & Internet
Where do i find the battery on a Acer Z5600 desktop
Desk tops do not have batteries.The Acer Aspire Z5600 does have a 250 watt power supply,which is a bit small.I recommend replacement with a larger power supply.
May 12, 2011 | Acer Aspire Z5600 PC Desktop
Where is the reset switch on an Acer Desk top computer?
your power button is on the right of the tower under the usb and sound ports. now for a reset button there is no such thin. that button will turn on and off your computer,. if u are looking to restore computer o factory default u should have got some system restore cds or when you boot it up you should see a f12 or f2 or f10 that will take you into system restore mode and you can restore system back to originally factory defaults.
Jan 07, 2011 | Acer Aspire™ T180 PC Desktop
ACER desk top computer does not start When I press the start button the light comes on the computer whirs for about 1 sec and then turns of. or nothing hapens. desktop ACE aspire ASX3200 8550 B1
There could be tons of reason for a computer not starting up! the first thing I would replace would be the power supply, then the memory sticks or even the entire motherboard could cause it. does the computer beep any tones when you first hit the power supply, no? replace the power supply unitassy.techman
May 08, 2010 | Computers & Internet
Aspire one model za3 user guide
Hello, your laptop is known as the Acer Aspire One 110, here is a direct link to the laptop from Acer. at the bottom of the screen you see a drop down menu for Technical Documentation, though I think Acer only have them in German? :-s
Jan 04, 2010 | Acer Aspire One AOA110-1113 Netbook
I can't open acercrystaleyewebcam aspire 5515
Go to Computer, program file, find webcam file, right click and add shortcut to your desk top.
Sep 09, 2009 | Acer Aspire 5610-4648 Notebook
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
Feb 18, 2009 | Acer Aspire 9300 Notebook
Power supply fo acer Aspire SA 60 desk top
To my knowledge, there is no limit to the maximum wattage that can be installed in your PC. The only limitations would be:
  • the physical dimension and mounting holes;
  • the connectors and wire/pin arrangements;
  • it should not be lower than what you currently have.
Jul 23, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
