My screen keeps telling me to auto scan channels?
    New Friend:
  • 53 Answers
This is for basic cable TV. If you have basic cable, go ahead and let it scan channels. If you have digital cable or anything else and use a INPUT or HDMI or RCA to watch TV then just ignore the scan channels prompt as you have a cable box that handles all that for you.
Posted on Apr 14, 2014
SD Tech
  • 14553 Answers
SOURCE: keeps telling me to scan for channels
most sets its done in the setup menu--select if cable or antenna and then select auto program, set will scan and store all available channels it can find.
Posted on May 20, 2012
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
bschilz
  • 2049 Answers
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-062_DX-R32TV_WEB.pdf
Posted on Sep 04, 2009
SOURCE: Incomplete Auto Scan of the channels
I ran the Auto Scan. Before the scan reached 91%, I pressed the Menu button on my remote and all of the channels that it found locked in.
Posted on Jan 08, 2010
SOURCE: My tv keeps saying to run auto channel scan.
FIRST, you must check ALL antenna connection, and if possible, try another "Known Good" antenna system. If it proves that the antenna system is all OK, then I fear your Tuner, has failed, this is a common event, that I get from time to time at my shop. Usually, it is a straight forward job and the cost would be about $250 - $350, depending exactly what is going on. However it would be best to get a "Quote" first, before proceeding, as this may only be a symptom, of a larger underlying problem, that may indeed cost much more.
Posted on May 23, 2010
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
Keeps telling me to run an auto channel scan
Check and replace its main system control memory IC. It is faulty. It does not hold the data. Gopakumar Gopalan Google
Feb 26, 2014 | Orion 24RTC 24 in. TV
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
Keeps telling me to scan for channels
May 19, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
The channel won't change and keeps telling me to perform an auto scan
well, did you perform the auto scan? the auto scan "scans" through channels and needs to be done.
Feb 03, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Televison & Video Logo
157 people viewed this question
Top Televison & Video Experts
