Question about Acer Computers & Internet
My computer will not power up when i push the power button its an acer aspire desk top
Power button will not work
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 94 Answers
First make sure that computer is getting power, check that AC cable is connected and led light is on behind the computer. Remove the cable for a while, then but it back in. Push down the power button for 10 seconds. Then try to start the computer.
Posted on Jun 04, 2014
  • 383 Answers
SOURCE: Laptop powers up but does not display desktop
How to enable / disable windows active desktop. Open Display Properties. Click the Web tab in the Display Properties window.
DirectX Help Get the computer into Safe Mode. In Safe mode, click Start / Settings / Control Panel and double-click on the display icon.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 22, 2007
yogesmaha
  • 69 Answers
SOURCE: acer aspire 5610-4491 laptop... NO POWER
remove battery and again insert it... then connect the a/c supply to the laptop and then check whether the power led is on or not .. if yes then on your laptop ..
Posted on Jun 17, 2008
SOURCE: Acer Aspire 6920 will not turn on. With or with
I had same problem with my aspire 6920.Tried power reset didn't work. Tried replacing memory chips,No go . Pulled rest of my hair out,still nothing . Then I checked memory chips again and noticed that the inner chip was not seating correctly due to a design flaw in the retainers. Gave both retainers a gental tweak,reset chips. And most importantly Disconnected CMOS Battery and held power button in for 1 min. Plugged everything back in and Bingo... Fired right up >>>And to the comment about plugging in the HD ....Mine fired up with out it ..
Posted on Sep 12, 2009
  • 104 Answers
SOURCE: Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Posted on Oct 16, 2009
  • 452 Answers
SOURCE: my acer aspire 6530 will not come on, i push the
This is a problem with either the controller or the GPU. check out the guide over at www.msbin.com it might help.
Posted on Jun 02, 2010
I have an acer aspire 1420-ur10p desk top and it wont power up, no beep light nothing, what do i do...
Check if power cord is working properly.
Check if power supply is working properly.
check if mothernboard is getting proper supply from power supply.
you can also get the cmos battery checked up
Apr 14, 2014 | Acer Aspire Ax1420-Ur10p Desktop PC
My aspire ast180-ea 350b won't power on
This sounds as though the power supply unit within the desktop has failed.
You should be able to buy a standard replacement from your local computer repair shop.
Dec 10, 2013 | Acer Aspire Computers & Internet
Where do i find the battery on a Acer Z5600 desktop
Desk tops do not have batteries.The Acer Aspire Z5600 does have a 250 watt power supply,which is a bit small.I recommend replacement with a larger power supply.
May 12, 2011 | Acer Aspire Z5600 PC Desktop
Where is the reset switch on an Acer Desk top computer?
your power button is on the right of the tower under the usb and sound ports. now for a reset button there is no such thin. that button will turn on and off your computer,. if u are looking to restore computer o factory default u should have got some system restore cds or when you boot it up you should see a f12 or f2 or f10 that will take you into system restore mode and you can restore system back to originally factory defaults.
Jan 07, 2011 | Acer Aspire™ T180 PC Desktop
I cant get a conection to my lap top, even when it is sittingon the desk beside the desk top and connected to the router linksys.
try turning off all 3 for 60 seconds, then powering back up modem...router...pc.
If that doesn't work, try running the network connection wizard
good luck
Oct 15, 2010 | Acer Aspire One PC Notebook
ACER desk top computer does not start When I press the start button the light comes on the computer whirs for about 1 sec and then turns of. or nothing hapens. desktop ACE aspire ASX3200 8550 B1
There could be tons of reason for a computer not starting up! the first thing I would replace would be the power supply, then the memory sticks or even the entire motherboard could cause it. does the computer beep any tones when you first hit the power supply, no? replace the power supply unitassy.techman
May 08, 2010 | Computers & Internet
I can't open acercrystaleyewebcam aspire 5515
Go to Computer, program file, find webcam file, right click and add shortcut to your desk top.
Sep 09, 2009 | Acer Aspire 5610-4648 Notebook
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
Feb 18, 2009 | Acer Aspire 9300 Notebook
Power supply fo acer Aspire SA 60 desk top
To my knowledge, there is no limit to the maximum wattage that can be installed in your PC. The only limitations would be:
  • the physical dimension and mounting holes;
  • the connectors and wire/pin arrangements;
  • it should not be lower than what you currently have.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
