Question about Exercise & Fitness
Tread mill power is on but treadmill not moving just beeping
  • 53 Answers
Does it need a safety key? Is it in all the way?
you might also need to check the connections in the back of the display and also where they connect inside the front arms down to the motor.
Posted on Apr 14, 2014
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
  • 33 Answers
SOURCE: the belt on the tread mill slips while operating
hai ,check the walking belt and motor belt tension
Posted on Oct 01, 2009
SOURCE: treadmill won't run. trys to start and gives up after 1-3 seconds
i am having the exact problem, any answers to this?
Posted on Dec 29, 2009
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Posted on Feb 12, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
Fix error 2 treadmill
this is a probably a faulty sensor speed see the diagram attached. However depend of your mark , model, can be e1 ,tight the connector very well, and clean it. Test the s.speed for open or faulty.
Oct 19, 2013 | Exercise & Fitness
Treadmill will not start up error comes up in window
please LUBE the deck belt with silicone or was see the owner manuals and proceed according. However if after you did lube the problem remain, is TIME to replace the old deck board.
God bless you
May 27, 2013 | PaceMaster Bronze Basic Treadmill
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
I just put my tread mill together Nordic Track A2550 and the belt wont move
1) test your circuit breaker home,reset
2)test the outlet for 115 vac
3)test the power cord if some wires is loose or cutting
4)reset your circuit breaker insider from your equipment
5)Eliminate any extension cord from your treadmill.
6)Be shure if the receptacle have ground cable with your divided TRSS.
sincerely.
ERNESTO CUADRA
MANAGUA,NICARAGUA. C.A.
Dec 11, 2011 | Nordic Track NordicTrack A2550 PRO...
I recently purchased a Bowflex treadmill and while I was walking on it, it stopped working and shows the error message "Safe Out" on the console. The safety button is in place and I tried...
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Dec 26, 2010 | Bowflex Exercise & Fitness
Tread mill doesnot move
Could be several problems. You can isolate the motor and use a DC power source (power tool battery, Lantern battery)to check if the motor is good. If the motor is good then check to see if under the motor hood you have a "Tech Sheet" which should help you with the diagnosis. We use www.treadmillpartszone.com for parts.
Jul 28, 2010 | HEALTHRIDER H75T Treadmill
I can't unfold my proform treadmill
there is a clip latch that u need to move to pull the treadmill back down, its on the left side on top
May 05, 2009 | Proform Exercise & Fitness
Jan 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
59 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
