Question about Asko Dryers
Overflow error Both condensers are empty dryer runs for a couple of min then stops with error showing
  • 53 Answers
Is your dryer duct clean? Check outside when it is running to see if it is blowing properly, the air should be hot and feel somewhat forceful. If it seems weak your dryer may be overheating because the ducts have become plugged.
Posted on Apr 14, 2014
  • Richard Sayer
    Richard Sayer Apr 14, 2014
    Oops, as this is a condenser type dryer. I wish a person could delete their own solutions when they are unhelpful.
  • 139 Answers
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Posted on Jan 21, 2008
awfhoog
  • 13 Answers
SOURCE: Dryer stops drying and lint error message...
The symptoms sound quite similar to this problem. You could try out its solution?
Posted on Jul 20, 2009
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Posted on Sep 10, 2009
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Posted on Jan 26, 2010
Siemens iq 750 keeps stopping after 3/4 mins of drying
Is your water jacket empty? Could be something simple like that.
Aug 07, 2016 | Siemens Dryers
Error code ee3
TE3' error code - Heating Error - High temperature thermistor open circuit. Could be the thermistor, high temp thermostat, etc. It shows an "open" code, which means something from point A to point B is open, and not grounding out. Check wiring, plugs, anything that could be bad or disconnected.
Nov 07, 2013 | LG Electronics DLEC855W Electric Dryer...
Empty out container
Yank out the condenser and wash it out is what I would try. Check the switch on the container chamber for correct positioning.Use this SERVICE MANUAL
Jun 16, 2012 | Dryers
Dec 05, 2009 | Hoover Dryers
Jul 09, 2008 | Dryers
try cleaning the vent line. if you have a flex vent line make sure it isn't kinked in any spot. make sure the outlet outside does not have a birds nest or anything blocking it
Nov 10, 2007 | Siemens WT79020EU Electric Dryer
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
Asko T780 Stopping after a few seconds.
It sounds like you have a condensing dryer. These condense the water into a pan in the back, and then the water is pumped down the drain. If you are getting an overflow, it means the pan is full of water and the controller is shutting it down to prevent it from leaking on the floor. Most likely cause is a bad drain pump, which is a bit of a bear to change as it is in the back behind the rear wall in the lower right hand corner. The other option is that the drain line could be pinched or clogged, especialy if the unit was moved just before the problem started. Hope this helps!
Mar 12, 2007 | Asko T780 Dryer
Dryers Logo
112 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
