Question about Emerson Go Action Cam 720p HD Digital Video Camera Pro Grade 5 mp Video With Screen WHITE
No file display - Emerson Go Action Cam 720p HD Digital Video Camera Pro Grade 5 mp Video With Screen WHITE
How do i upgrade firmware of sharp mx2700n copier
To update the firmware, set DIP SW 2 on the MFP control PWB to ON.
1) Insert the USB memory into the machine.
* When USB is not connected, "INSERT A STORAGE FIRMWARE STORED ON" is displayed. When [OK] button is pressed, the display is shifted to the folder or file selection screen.
2) When a firmware update folder or file button is pressed, the display is shifted to the firmware update screen.
* The number of buttons depends on the number of files in the inserted USB memory.
A folder name or file name is displayed on the button.
If the folder name or file name is of more than 34 characters, only 34 characters are displayed.
For a folder name, "<DIR>" is displayed at the head.
* When [ .. ] button is pressed on the file selection screen, the display is shifted to the folder or file selection screen. On the folder or file selection screen, the keys are disabled.
* The path of the folder or file is displayed on the title section.
If the path is of more than 50 characters, only 50 characters are displayed.
Read more >> http://electrohelponline.blogspot.com/
Aug 19, 2016 | Sharp MX-2700N copier
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
How to delete console port and telnet passwords through BootROM?
1. Connect a PC to the device with a serial cable and log in to the device through the console port.
2. Restart the device. When the message "Press Ctrl+B to break auto startup ..." is displayed, press Ctrl+B and enter the password to display the BootROM main menu.
3. Select choice 4 to enter the Startup Select menu.
4. Select choice 1 to view the system configuration.
In V200R001C01SPC300 and later versions, you can use the following method to view the configuration file. In Huawei V200R001C01SPC300, the menu choice is Startup Information. In Startup Information and later versions, the menu choice is Display Startup.
Startup Select
1. Display Startup
2. Set Boot File
3. Set Config File
4. Startupfile Check Manage
0. return
Enter your choice (0-4):1
************** Current Stratup info ****************
Valid Flag State : Vaild
Boot File Name : sd1:/software.cc
Config File Name : sd1:/vrpcfg.cfg
Licence File Name :
Patch State : Deactivate
Patch File Name :
Voice File Name :
In V200R001C01SPC200 and earlier versions, the configuration file cannot be viewed. The system often uses the file vrpcfg.zip or iascfg.zip.
5. Rename the configuration file.
6. Restart RouterA.
7. Stop Auto-Config.
8. Change the renamed configuration file to executable file. Select one file format.
9. Restore the configuration.
Aug 19, 2015 | Computers & Internet
Clear memory for change in ownership
1. In the Time of day display scroll up or down until FILE is displayed.
2. Press and hold the signal/light button. DELETE FILES is displayed.
3. Press OK. The wrist unit confirms if you want to delete all files
(Are you sure).
4. Press OK to delete all exercise files.
5. Press stop to return to the Time of day display.
May 14, 2015 | Polar 725x Tour Edition & Accessories
I have a full memory need to delete files and forgot how
Here are some steps to delete a file in your Polar watch.
Deleting a file
2. Press OK to enter the File mode.
3. Scroll up or down until desired exercise file is displayed. Press and hold
the signal/light button. DELETE FILE and file number are displayed.
4. Press OK. The wrist unit confirms if you want to delete a file
(Are you sure).
5. Press OK to delete the selected file.
6. Press stop to exit the file. Wait appears. The wrist unit rearranges your
file, which takes few seconds.
7. Repress stop to return to the Time of day display
Deleting all files
(Are you sure).
For more information, refer to manual of the watch.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 16, 2011 | Polar S S625X Wrist Watch
Whenever I load photos onto my photo frame from the PC, they all seem to transfer just fine. But then when running the slideshow, not all the pictures are showing up. When I go into the photo menu on the...
The issue may be due to the file types of the pictures you are sending to the frame. You did not include the model number of the frame, so I can't be sure of the file types it can display but generally, JPG file types enjoy the most compatibility on such devices.
You should determine the file types of the images you are sending to the display. While displaying the slideshow, make a note of an image that displays properly. Look at the the image on your computer and check the file details to learn which file type it is. Play the slideshow on the frame and double check as many as you can against the list / thumbnails on the computer. After a short time, a trend show be visible. You may find that JPG and GIF files display properly, but TIF and others do not.
If you want those pictures to display, you'll have to convert them to one of the file types that does display. If you're finding that only some JPG (or other displayable file type) do not display properly, you'll have to see what is different. Sometimes, very large files may not display correctly, or it may have "too much color" information (they might be a 16 bit graphic or 16 million colors instead of an 8 bit graphic or 256 colors), or some other issue that isn't readily apparent. You can try resizing or converting to yet another format that is supported by the display (GIF for instance).
This is a starting point - hopefully you'll find the issue within one of these suggestions. Good luck! Please rate my reply - thank you.
Feb 24, 2011 | Philips 6.5-Inch Digital Photo Frame...
Failde to download.ini file
Three possible conditions possible. First, the media requiring download is corrupted. A source from the network would possibly display a nonexistent program attachment. A common message soon after download is display of an error ro corruption of what has been acquired on the computer. A disk medium being downloaded would display a download error when damaged.Second, a program already existing on the computer producing fail displays are corrupted either has been deleted or integrated by a malware software producing malfucntion. Third, the computer system on which attempting to download .ini. files could be incompartible with the file. An outdated computer system, or an outdated computer program, or a versions of compartibility of the system to the medium files displays the warning message produced.
improtant notes
1. Check the compartibility of the computer operating system with the media file attempting to be downloaded.
2 a compartible computer could require updates to function with the file
3. The .ini file could require decoding to produce a display on the computer
4. attempt to download on another computer version to check for compartibility
contact technical assistance if persistant
Dec 20, 2010 | Logitech Computers & Internet
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
mode.
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
Not displaying all files while connected as a USb
Your MP3 player is virused. clean virus then and in your pc done : tools-Folder option -view-(mark)show hidden files.. and (unmark) hide extension ... , hide protected... so change hidden folders in your MP3 player
Dec 17, 2007 | Samsung YP-U2X Digital Media Player
Emerson Go Action Cam 720p HD Digital Video Camera Pro Grade 5 mp Video With Screen WHITE Logo
18 people viewed this question
Top Emerson Cameras Experts
Are you an Emerson Camera Expert? Answer questions, earn points and help others
